Old 05-28-2017, 10:40 AM   #1
JeffnBessIllinois's Avatar
Panel
Can someone tell me what the dsi-flt light is for Click image for larger version
JeffnBessIllinois is offline   Reply With Quote
Old 05-28-2017, 10:54 AM   #2
AquaMan's Avatar
It tells you that your water heater is lighted or not. If the light stays on, it did not light. Wait a few minutes and try again.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2019 - 17
Old 05-28-2017, 12:38 PM   #3
Oakman's Avatar
The light is the Direct Spark Ignition Fault Light. When you first push the water heater switch that light should come on and stay on until the propane ignites and then should go out. If it stays on for more than a minute turn the water heater off and try again. If you have air in the propane line going to the water heater it might take a couple of attempts to light the water heater.
Bob and Joyce
2013 CC Silverback 29RL
2010 Ford F250 XL Crew Cab 6.4 liter diesel
ATU Local 788
Oakman is offline   Reply With Quote
Old 05-28-2017, 06:45 PM   #4
If you are hooked up to shore power and not using propane to heat with, is the water heater switch supposed to be off?
mattstacie is offline   Reply With Quote
Old 05-28-2017, 06:48 PM   #5
Yes, if you have the electric option to heat your water heater, the switch on your panel should be off.
You have to go outside to turn the electric portion on to heat the water heater on most models.
Mark B.
2021 GMC 1500
Anderson WDH
markb5900 is offline   Reply With Quote
