Originally Posted by sgtlm17
That is simply a plug that is wired to your batteries. It allows you to plug a portable solar panel in to assist with battery charging while boondocking or disconnected from shore power. Simply put its a wire to the positive and the negative terminals of the coaches battery. Take note the plug is a Zamp which is the manufacturer. You can plug a Zamp portable panel in very easily. Other portable panel manufacturers have reversed wiring compared to Zamp and you would need a plug adapter to reverse the polarity.
As you say, this plug would allow a solar panel to keep you coach batteries charged. I am thinking about a small panel that I can use to trickle charge the batteries ... but what about the chassis battery? Will this plug keep the chassis battery maintained?
This is mostly for storage. I hear about other manufacter's coaches where the chassis battery is drained in only a couple of weeks by the dash radio.
