Old 07-11-2016, 09:28 PM   #11
TSB
I have never seen those before. Where do you get those? Do they come with a pump?
TSB is offline   Reply With Quote
Old 07-11-2016, 10:21 PM   #12
Kenny kustom's Avatar
https://www.amazon.com/gp/aw/d/B009O...ANL&ref=plSrch
I have the 60 gal. Was $134.
I use the factory pump that my trailer came with. Plugs into my trailer and bladder sits on the bed.
I replaced that pump with a remco.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
Old 07-12-2016, 01:19 AM   #13
Fulltime family RVer
Originally Posted by doc73 View Post
I use the winterizing port to suck water into the plumbing.. Then the outside shower hose (nozzle off) to pump it back into the tank through the fill port
Same. It's great if you have a water bay where it's all close together.
2012 Ram 3500 DRW/crew cab/long bed/4x4/4.10 gears pulling an early 2013 Sabre 36QBOK
Old 07-12-2016, 10:55 AM   #14
I got one of this and cut the wand off, added more tubing. Hook up to battery and it pumps it right in 30 gallons at a time, if you need that much! Works great.
Thanks! Where did you buy this??
Wolverine308 is offline   Reply With Quote
Old 07-12-2016, 01:41 PM   #15
Call me whatever name you wish.....but I don't understand the OP's problem.
2012 Ecoboost Screw, 3.31 (yes....really) rear end.
2016 Flagstaff 26FKWS, about 7500 loaded
Retired AF Mustang.....Picker always looking to jam.
Major Oz is offline   Reply With Quote
Old 07-12-2016, 01:46 PM   #16
AquaMan's Avatar
Op is at a site that doesn't have a water hookup. Wants to fill his tank up, but not move off the site. Giving him ideas on how we've managed a work around this problem
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 07-12-2016, 02:25 PM   #17
dmchapman's Avatar
My gravity fill is near the front of the trailer. The anitfreeze, city water and outdoor shower are on the rear. Yesterday I bought a male hose end fitting ($5) and 4' of 5/8" vinyl tubing ($4). I can set the 5 gallon jug on the ground or balance it on the rear bumper and dip the hose into the jug. One valve inside the trailer can change the pump intake from FW tank to antifreeze fitting. Haven't tested it yet but it should work.
2015 Microlite 21 DS
2012 Silverado extended cab Z71
dmchapman is offline   Reply With Quote
Old 07-12-2016, 05:30 PM   #18
I generally carry a 5 gallon collapsible jug to refill. However, when close enough to a common water faucet, I will use my hose with a water bandit (or water thief depending upon the brand) to connect to the thread-less faucets in many campgrounds for a quick fill.
wboglejr is offline   Reply With Quote
Old 07-12-2016, 09:09 PM   #19
vasnipe's Avatar
Water / sprayer tank
If you are looking for a spray tank like the one referenced above there are several sources. Northern Tool is one:
Garden Sprayers + Lawn Sprayers | Lawn + Garden | Northern Tool + Equipment
Tractor Supply
Sprayers & Chemicals Online or In Stores | For Life Out Here
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 07-13-2016, 04:53 PM   #20
I carry one of the standard 6 gallon blue water jugs for this very reason. I fill it at the campground faucet, then transfer the water directly into the fresh water fill using a small (1-1/2" wide by 5" long) 12dc submergible water pump that drops right into the jug. This pump, a Rule i200 sold on Amazon for 26 bucks, transfers water at a rate of 1 gallon in 20 seconds. The pump is a simple 2-wire connection and it's outlet port uses either 1/2" or 3/8" tubing you acquire and cut for your purpose. The best part is it transfers the water from the jug while it's on the ground, meaning no lifting. 2 trips equals 12 gallons of water...
metalsideup is offline   Reply With Quote
fresh water, water
