Old 07-11-2016, 08:39 PM   #1
Topping off fresh water
Any suggestions for topping off the fresh water while camping at a park that is NOT full hookup? Sure do not want to have to haul the trailer down to fill up. We have a Vibe 308 BHS.
Wolverine308 is offline   Reply With Quote
Old 07-11-2016, 08:44 PM   #2
SeaDog's Avatar
I have several six gallon for fw only containers that are easy to put in the back of the truck and go get extra water. I think you can buy them at wally world
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-11-2016, 08:52 PM   #3
We have some too, but this trailer, which is a 2016, has a vent over the water opening. Needs forced water to fill not gravity. The best I can describe, is like it needs a hose connected to it. Our previous unit used the jugs just fine. Thanks for the input.
Old 07-11-2016, 09:06 PM   #4
Buy a spare water pump and mire it up with some alligator clips to power if from the tv and get a couple of short pieces of hose and use that from your portable water jugs to the trailer.. Allow it to dry before putting it away and keep it clean.. Ideally if you got one that is the same as your trailer, you'd have a back-up water pump in case the one in your trailer dies in years to come...
Camped 2016 (Days/Nights) - 32/23
Nights camped 2015 - 29
TT: 2013 26' Revere TBQB
TV: 2014 GMC Sierra 1500 Z71 4x4
glen1971 is offline   Reply With Quote
Old 07-11-2016, 09:10 PM   #5
DaveSchwartz's Avatar
This may not be totally practical for you but works for me. On a previous TT, I replaced the sick-water-buffalo-sounding water pump with a variable-speed drive pump and so had an extra pump lying around. I configured it with hose ends and when I need water, I carry 5-gallon blue jugs from the hydrant, and pump it through a filter into the FW tank.
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
DaveSchwartz is offline   Reply With Quote
Old 07-11-2016, 09:10 PM   #6
Carknocker Family
Ida Ratherbe Camping's Avatar
Sounds like your water fill may have an upward arch to it. Ours did, would not take a gravity fill. Just poured on ground.
Luckily, I was able to get to it and cut the "extra" hose off to get it angled down. Now no problems. We use the six gallon jugs now to fill when no hookups.
Nights camped 2014...26
Nights camped 2015...20
Nights camped 2016...20
2005 Dodge 2500 5.9 Cummins 6 speed manual
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 07-11-2016, 09:32 PM   #7
Thanks for the advice!
Old 07-11-2016, 09:51 PM   #8
Who Dares, Wins
doc73's Avatar
I use the winterizing port to suck water into the plumbing.. Then the outside shower hose (nozzle off) to pump it back into the tank through the fill port
Sent from my SM-G930V using Tapatalk
Pat, Jen & Heather... Oh yeah and our trained attack trailer cat, Cinnamon
2015 ChevyHD D-Max
2014 Greywolf 26DBH
doc73 is offline   Reply With Quote
Old 07-11-2016, 10:15 PM   #9
TSB
I got one of this and cut the wand off, added more tubing. Hook up to battery and it pumps it right in 30 gallons at a time, if you need that much! Works great.
TSB is offline   Reply With Quote
Old 07-11-2016, 10:19 PM   #10
Kenny kustom's Avatar
Yup.
Except I picked up an aqua tank 2.
60 gal bladder that folds up small.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
fresh water, water
