Old 08-29-2012, 07:08 PM   #1
TV outlets
there is a tv outlet in the bedroom of our trailer and it has no label. anyone know how it is wired? is it whatever the front tv is on or is it only on the antenna? thanks
[/SIGPIC]2012 Vibe 6502
2004 Dodge Dakota
dbuzz77 is offline   Reply With Quote
Old 08-29-2012, 07:59 PM   #2
TURBS's Avatar
It's hooked to over the air antenna
Old 08-29-2012, 08:01 PM   #3
Road-King's Avatar
If it's like most RV's, if the antenna amp switch is on (pushed in with little green light) then it is on the antenna. If antenna amp switch is off then it is wired to the cable tv hook-up...
Welcome to the forums....
Russ & Kim
2014 Alpine 3600RS
2007 Dodge Ram 3500 5.9 4X4
2008 Harley Davidson Road King 105th Anniversary
(2011-5 bad year)(2012-40)(2013-45)(2014-23)
Road-King is offline   Reply With Quote
Old 08-29-2012, 08:22 PM   #4
awesome, thanks. i guess the dvd only goes to the 1 tv then.
2004 Dodge Dakota
Old 08-29-2012, 08:28 PM   #5
Yes the dvd only goes to the tv. You may want to try the dvd before you go camping, they had ours hooked up wrong and i had to pull the stereo to fix it.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 08-29-2012, 08:58 PM   #6
ya, my cable from the dvd to the wall jack is open
2004 Dodge Dakota
Old 08-29-2012, 09:03 PM   #7
Eaglelover's Avatar
Send a message via Skype™ to Eaglelover
TV Antenna
Hi Road King: I have never heard that the push button switch on the control plate for the antenna changes the input to the TV. As far as I know the button turns on the antenna booster when the green light is lit to help with weak on air signals. I better check my manual. Thanks; Frank
Eaglelover is offline   Reply With Quote
Old 08-29-2012, 09:21 PM   #8
Road-King's Avatar
On the three campers I've had it does turn on/off the amp, but it also is a A/B switch. On for the amp and antenna, off for no amp and cable tv...
Russ & Kim
2014 Alpine 3600RS
Old 08-29-2012, 09:32 PM   #9
Eaglelover's Avatar
TV Antenna
Road-King: Thanks for the info. I will check this out. I have a 2012 3001W Windjammer. Frank
Old 08-29-2012, 09:41 PM   #10
Road-King's Avatar
We are loving ours. Got it the end of June and spent 25 nights in it already. I have not found a good way to get the shaking out of it yet, but still working on it.
Russ & Kim
2014 Alpine 3600RS
