Old 07-20-2015, 02:49 PM   #1
V-cross Vibe 823VDS5 no gravity fill fresh water
I have the 5th wheel V-cross vibe that has 3 garden hose connectors in the rear....Black tank flush, Fresh water fill and Street water supply. I was going to cleans the fresh water tank with a bleach/water mix. When I hooked up a short piece of hose and a funnel to the fresh water input, I got nothing but over flow....none went in. So now I realize that I won't be able to go boondocking and siphon water from a jug INTO the tank !!! online research has yielded the concensus that for this type of system we MUST purchase an external pump to fill the fresh water tank. Glad I discovered this at home and not out in the wilderness somewhere! Can anyone verify this design?
hiker108 is offline   Reply With Quote
Old 07-20-2015, 10:12 PM   #2
Our Vibe has the same setup which was a surprise from our previous unit which had a large fill port that could be filled from most any container. There must be a one way valve to prevent backflow when connected on the "City Water" port. Even if this were not the case, gravity flow thru a 1/2" line would be extremely slow. I have used my Zodi shower pump to transfer water from jugs into the fresh water tank (slow). Considered buying a 12v pump from Harbor Freight but hate adding to my equipment list. Final solution was to "dual purpose" the hand operated pump for our kayaks to transfer water;
http://www.amazon.com/Seattle-Sports...ayak+hand+pump
pjnlorrie is offline   Reply With Quote
Old 07-21-2015, 09:19 AM   #3
Yea sucks. What they call improvements I call PITAs. Anyway seems to be the way FR is doing it now. Don't know about other manufactures.
George Scott
2015 Salem Hemisphere Lite 272RLIS/ Prodigy P3
2006 Heartland BH 3400/Summer Home
2007 Dodge 2500 CDT QCSB/Blue Ox Sway Pro 1500lb WDH, Maxxis 8008 225 x 75 x15 LR E tires/J T Strongarms
Scotty is offline   Reply With Quote
Old 10-03-2015, 07:58 PM   #4
Wingdreamer's Avatar
I mades this kit up with a Rubbermaid tote and a shurflo pump. Worth spending a little extra $ for the shurflo, as its self priming and can safely run dry. I run it from the trailer battery with a standard 2 pin trailer plug/ pigttail attached to the battery. Love it!
Name:	2015-07-14 10.27.30.jpg
ID:	90594   Click image for larger version
Name:	2015-07-14 10.27.58.jpg
ID:	90595   Click image for larger version
Name:	2015-07-14 10.27.42.jpg
ID:	90596   Click image for larger version
Name:	2015-07-10 18.01.23.jpg
ID:	90597   Click image for larger version
Name:	2015-07-14 10.30.08.jpg
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
Old 10-03-2015, 08:25 PM   #5
Now THAT is a totally done job!
Old 10-03-2015, 10:27 PM   #6
Thx! Whole job took about 3 hours to do, works awesome. At first I was really upset that I didnt have a gravity fill on my Vibe, so I had no choice but to get a pump and make something up. I leave it hooked up and plugged in while camping. I just put the lid on it and tuck it under the edge of the trailer. Pumping the water in with this works soooo good that I actually find it easier
fresh water, v-cross, vibe, water
