Old 04-14-2015, 09:33 PM   #1
Vcross Platinum Fifth Wheel - unknown plumbing hose ??
I have a 2013 Vcross Platinum . There is a miscellaneous hose in the external input area below the fresh and city water inputs that is unlabeled. It has a 1/2" PVC male fitting. Who can tell me what it is for? I think it is the Winterizer input hose to the freshwater lines, but I'm not sure.
Picture attached. It's the left hose with the black cap under the city water input.
It seems I cant attach the picture from my ipad. I will post another thread unless someone knows this answer without seeing it.
Terry - Houston Texas
wb4pgf is offline   Reply With Quote
Old 04-15-2015, 09:03 PM   #2
Photo of Unknown hose
Here is a picture of the water input area. The bottom left hose is the one in question with the black cap. What is it for?
Old 04-15-2015, 09:08 PM   #3
tbritt's Avatar
Could it be your Black Tank flush?
2012 GMC 2500 HD
2011 303 RK LaCrosse Luxury Lite
Days camped 2010: 274
2011: 365
2012: 365
tbritt is offline   Reply With Quote
Old 04-17-2015, 09:15 AM   #4
Texas Bohunk's Avatar
That's to winterize you fresh water system. Just stick that hose in a gallon of RV antifreeze and turn on the water pump. Go inside the trailer and open the faucets until the antifreeze starts coming out. Be sure to block off and drain you water heater.
2014 V-Cross Platinum 365VTSB
2002 Frontier 305S bumper pull
2013 Dodge Ram 2500 4X4 6.7 Cummins Automatic Trans. AFE aftermarket air filter, Curt 24k slider hitch
Texas Bohunk is offline   Reply With Quote
Old 04-17-2015, 08:48 PM   #5
Thanks. That is what I thought. I did it manually thru pumping into the freshwater inlet this past winter.
Have a great day.
fifth wheel, plumbing, wheel
