Old 10-13-2013, 01:37 PM   #71
Blubear's Avatar
2014 Vibe 6502 Specs
Originally Posted by pdchristensen View Post
As far as I know they are still coming out of production with 3500 lb axles. You would be able to tell by the GVWR and CCC on the specs.
Just checked the Actual "stamped" Specs on this 2014 Vibe 6502:
Dry WT = 3252
CCC = 1441
GVWR = 4710
GAWR = 4400
Tires are 15"
My guess (and only a guess) is FR has addressed the axle issue. STILL I will not be loading heavy in Aft storage.
Blubear is offline   Reply With Quote
Old 10-16-2013, 01:57 PM   #72
Winnipeg,Manitoba-Canada
pdchristensen's Avatar
Dry WT = 3252
CCC = 1441
GVWR = 4710
GAWR = 4400
Tires are 15"
That would be good news. I assume they have not got around to updating their website specs for the 2014 models.
2015 Rockwood 2306 MiniLite
2012 Chevy Traverse
2011-2014 - 50 nights
Paul, Darcie, Li & Yan
pdchristensen is offline   Reply With Quote
Old 10-16-2013, 02:01 PM   #73
Dry WT = 3252
CCC = 1441
GVWR = 4710
GAWR = 4400
Tires are 15"
I am not sure if all 2014's have those specs..
https://www.couchsrvnation.com/fores...ibe/vibe-65023
2012 Chevy Traverse
Old 10-16-2013, 02:05 PM   #74
Dry WT = 3252
CCC = 1441
GVWR = 4710
GAWR = 4400
Tires are 15"
Either the dealers are all messed up or there is an upgraded version of the VIBE coming off the line..
New 2014 Forest River RV V-CROSS VIBE 6504 Travel Trailers at Collier RV Super Center Rockford Illinois Collier RV Super Center
2012 Chevy Traverse
Old 10-19-2013, 06:33 PM   #75
Blubear's Avatar
Who knows what's going on as I've noticed the same "numbers" but I'm going by the numbers "Stamped" on my TT.
Old 02-21-2014, 05:13 PM   #76
I am in Winnipeg, Manitoba, Canada - Directly north of Grand Forks N.D.
I am sure we get just as much snow if not more. With the cover on a most of the snow tends to slide off the A/C however with significant build up I could see it being a problem.
Figured I'd report in now that we have some snow
This is a picture I took today of our Vibe. It looks less tall than normal because there's roughly 3ft of snow on the ground around it. There's a solid 2ft of snow sitting on the roof. Still nice and dry inside though. I did not try to build any sort of protection box around the A/C unit. I expect it will be fine but we will need to replace the cover every couple of years as they tend to become torn by the ice weight, based on experience with previous trailers.
dboreham is offline   Reply With Quote
Old 02-21-2014, 05:45 PM   #77
Blubear's Avatar
We have not had that much snow here in PA and have had some melting over the past couple days too. Next year I'm investing in an RV Cover! I've gone out after each significant storm and cleared the snow off the roof .... maybe I'm being over cautious .... and I think if I had a cover on it I would not feel as compelled to clean it off. I'm just ready for SPRING!
