Old 10-01-2012, 10:30 AM   #1
Winnipeg,Manitoba-Canada
pdchristensen's Avatar
VCROSS Sway Control
Has anyone installed weight distribution/sway control on the VCROSS series? If so can you enlighten me on what you may have used as it seems to me that the limited visible area on the frame from the hitch ball to the trailer would restrict the type of system you could use.
I have never installed one before so I am not sure if this limited frame length would be an issue.
2015 Rockwood 2306 MiniLite
2012 Chevy Traverse
2011-2014 - 50 nights
Paul, Darcie, Li & Yan
pdchristensen is offline   Reply With Quote
Old 10-01-2012, 10:57 AM   #2
Old car's Avatar
I have a Windjammer which is the Rockwood sister to your trailer. I use the Equalizer 4 point weight distribution/sway control set up on my 3008W. I have the 10,000 lb. bars for my set up and so far all has been working very well.
Randy and Patty
2015 Sabre 33 CKTS-6 Platinum Edition
Reese 16K Slider hitch
2015 GMC Sierra 3500HD diesel dually
Old car is offline   Reply With Quote
Old 10-01-2012, 11:31 AM   #3
The only way we could get the E2 WDH to work on my 6501 was to weld the bracket to the frame, I've heard that they come with the bracket installed on the later models, the factory told my dealer to remove the trailer from the frame to install it but there was no way they were going to do that. The only other hitch I have seen that might work is the blue ox, they have a bolt on rotating latch.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 10-01-2012, 11:43 AM   #4
Thanks for the feedback.
My thinking is that maybe I do not need weight distribution as much as just sway control. I think the tongue weight on the 6500 series is only around 300 lbs, so maybe I could just get away with a say control product such as this link.
CURT Manufacturing | CURT Manufacturing - CURT Sway Control Kit #17200
Forum feedback is always appreciated, thanks.
2012 Chevy Traverse
Old 10-01-2012, 12:04 PM   #5
you may be able to get away with just sway control. The dealer I bought from sold one to a person with an MDX with just sway control. In my case with the minivan the combination of soft rear suspension and a hitch that sits low under the bumper made it necessary to have the WDH. You could just load up the TV as you would for camping and see how low it sits. One thing to watch out for is taking too much weight off the front wheels.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 10-04-2012, 08:56 PM   #6
my unit does not sway at all even after quick lane changes. my friend brought up that the v front would be more stable than a flat or tilted front because the wind resistance is split instead of being allowed to buffet. i think after towing i agree. i looked at a sway control but i don't think i need one.
[/SIGPIC]2012 Vibe 6502
2004 Dodge Dakota
dbuzz77 is offline   Reply With Quote
Old 10-04-2012, 10:43 PM   #7
bikendan's Avatar
many V-nose owners have had no problems with the Equalizer.
you definitely will need a WDH with a Traverse.!
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 10-05-2012, 07:15 AM   #8
I appreciate the feedback bikendan - why do you feel I would "definitely" need a WDH ?
2012 Chevy Traverse
Old 10-05-2012, 07:21 AM   #9
Alleged curmudgeon
Vern's Avatar
Agree with Old Car...
x2...Same experience to report with my Windjammer.
Edit: I just realized you are talking the "Vibe" line and not the original V-Cross line (which is more like my Windjammer). You state around 300# (very light) hitch weight. No experience with that and will defer to others as to whether WD is needed or not.
Lee
2013 Windjammer 3008W
2006 Chevy Silverado 2500HD 6.0L w/Equalizer 4
Nights camped: 2012 (29); 2013 (26); 2014 (40); 2015 (43); 2016 (35); 2017 (34)
Vern is offline   Reply With Quote
Old 10-05-2012, 09:42 AM   #10
bikendan's Avatar
the actual tongue weight, when loaded, will be at or over the Traverse's max.
this is because the passengers and cargo will also affect its payload and then you also factor in the typical overly soft suspension of SUV's.
