Originally Posted by Wybdgrl
Is there a special type of sealant we should use around our vents on the room of our Vibe?
Thanks!
Dicor self leveling, would be my first choice, but if you are only putting a bead around the vent itself do not use self leveling. Dicor also makes a caulk. All depends on what you need to seal. I'm pretty sure and someone correct me if I'm wrong but I think that is what the Factory use's. either way it will still work. CW sells it and most RV outlet stores.
