Old 02-22-2018, 02:05 PM   #1
RolltideRoo's Avatar
Vibe 2018 313bhs battery disconnect install DIY
Anyone done one yet? I've looked st the Batt wires and they'd seem to split to different parts of trailer. Question is can one dual switch work or will I need a disconnect on each line separate? Click image for larger version
RolltideRoo is offline   Reply With Quote
Old 02-22-2018, 02:13 PM   #2
Fulltime family RVer
Move everything from the battery to the switch and then add a new cable between the switch and the battery.
ependydad is online now   Reply With Quote
Old 02-22-2018, 02:34 PM   #3
I get that I re-did my whole boat batteries and moved them, sorry I should asked the question better, my fault! But the question is do these two batteries feed different items in the trailer? One to the converter, one to another destination? Or is just in parallel feeding the fuse panel? To much spray foam and covering to follow.
Old 02-22-2018, 03:02 PM   #4
In parallel feeding the fuse panel.
Some people will put in a battery selector switch so that they can use 1 battery first and then the other.
Old 02-22-2018, 03:22 PM   #5
One in pic is one like my boat, I can use one or the other or both, volts stay same but amps increase in parallel and both on. Thanks for the input!
Old 02-23-2018, 07:05 AM   #6
I have same trailer. I bought 2... 4 post bussbar to attach everything to. Wire batteries in parallel then wire to battery disconnect then to busbar. This way all of my connection are not at the battery and makes it easier to remove battery. First 2 pics are the mess, when it gets warmer out im redoing everything.Click image for larger version
ID:	163140Click image for larger version
ID:	163141Click image for larger version
cmysstailights is offline   Reply With Quote
Old 02-23-2018, 08:07 AM   #7
cavie's Avatar
Be sure your trailer doesn't have 2 six volt batteries in series.
2002 27rk Wildcat 5er.
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
cavie is online now   Reply With Quote
Old 02-23-2018, 08:11 AM   #8
Prime Member
..and don't mistakenly wire (2) 12V batteries in series.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is online now   Reply With Quote
Old 02-23-2018, 01:26 PM   #9
They don't come with six volt batts.
Old 02-23-2018, 01:31 PM   #10
According to the sticker on the side of my trailer, the converter needs both batteries wired in parallel to run. So I'll just put a single bank shutoff.
battery, battery disconnect, vibe
