Old 08-13-2016, 07:13 AM   #1
Vibe 268RKS
Two weeks old still parked in yard waiting for flooding to subside before ferrying it down to the Gulf coast for a fishing/hunting camp. The first thing I did was replace the mattress with a nice Denver with the pad and sheets.i added a 24" Samsung in the bedroom . We gave the 32 inch Jensen away and replaced with a 40 inch Jensen. We use the Dish network Tailgator system , and Actiontech wireless Hi Def for wonderfull hi def on both TVs without the wall connections. I mount the Tailgator on the barbque swing arm on the back with a hi def 6' coax. I can zero it in and tighten the bolt on the swing arm to keep it in place. Lost the little fridge to store the Tailgator in while away. Added the best surge protector and a adjustable water pressure fitting. We took one on the easychairs out also , which opens up the space nicely . The firdge was mounted improperly , so I had to grind off the double flange mounting fitting as it was mounted so that the flange was crushing the freezer gasket allowing air into the freezer ! I used a heat gun to repair the gasket . I finished the silicone job on the shower, it was only half done. This thing is heaven for a do it yourselfer gearhead !! LOL
Oh I also did the repair job shown on this forum regarding the rediculous strap on the electrical wires under the slide out .It broke to peices just sitting in the yard .
Next will be replacing these Chinee tires ! They need to give us the option to pay extra for decent tires.
So far so good !!!
Jaymundo is offline   Reply With Quote
Old 09-01-2016, 06:55 PM   #2
Dometic AC
I have the 2017 model with 15k AC . Is it the Brisk II or something else ? Dealer just put the serial number on spec sheet , no model number . Thanks
vibe
