Old 07-22-2016, 01:33 PM   #11
Well not to defend the Company,but a lot of these camp grounds don't have the correct size wire feeding the pedestals . The use too small of a wire feeding them. That causes voltage drop and the breakers are tripping due to heat issues. Next time see how full the park is and see if it trips.
vibe268rks is offline   Reply With Quote
Old 07-22-2016, 03:28 PM   #12
Toolman_GA's Avatar
Just got of a 7 night camp in N.Ga over the 4th of July in a 2017 268rks. Had AC on all the time. Came with the 15k single unit. Temps were in the low-mid 90s every day. We found that if you open the direct vent at the AC unit but cooled the main cabin better during heat of day. We run everything full tilt when camping trying to make it break while under warranty (residential fridge, outside fridge, microwave, TV, lights, AC. No problems and this is our 4th camp. It is a lightweight build so can't manhandle the doors and stuff for sure...
Steve/Pam - 1997 Silverado K1500, 5.7L, Z-71 with Factory Tow package. Not quite yet retired but getting there... USN - sorry, no more free rides for my USMC buddies....
Kennesaw, Georgia
Toolman_GA is offline   Reply With Quote
Old 07-22-2016, 06:23 PM   #13
New Vibe owner Pick up a 224 RLS
I hope this was not a big mistake, the vibes seem to be built as good as any of the travel trailers? Have never had a travel trailer will be pulling it with a 2015 F150 eco boost super cab weight seems to match up good. Hope no over weight problems. The 224 RLS is only 4800 lbs and tongue weight of 550 or so. My F150 has the heavy duty tow package with 2200 lbs of payload. Would like to hear from other vibe owners on issues to look for.
porkchopjack is offline   Reply With Quote
Old 07-24-2016, 07:31 PM   #14
I pull mine with a 2012 Tundra 4x4. pulls great. be sure to have your wdh . that makes a big difference.
Old 07-24-2016, 08:06 PM   #15
Porkchoplack I tow our 272 bhs with a 2011 f150 eco boost installed load range e tires on truck and e rang tires on trailer tows perfect our trailer has had minor is sure but solid otherwise matinance is always required on all trailers before and after every trip by doing so you will prevent most issuer good luck ad safe travels
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
air conditioner, vibe
