Vibe 272 bhs winterization pump kit
Installed my Atwood antifreeze kit on the water pump and ya it's a chore. The pump is in the tightest spot under the stove .first have to remove the panel under the stove then remove the false wall panel where the trash can is located and attack the pump from both areas. if the pump was 1/2 inch closer to the wall I would have had to relocate the pump a few inches. Who ever designs these units apparently never has to work on them.on the brights side once it's installed it's all down hill the next time winterization is needed . The bad thing about where the pump is located is their is a screen trap for partials on the pump and if it ever needs service it's not going to be EASY.
Clancy vibe272bhs
