Old 04-11-2014, 05:53 PM   #1
Blubear's Avatar
Vibe 6502-Water draining when moving
I did the whole de-winterize this past weekend and returned the tt to the secure lot I store it and water is draining (only when moving) from the 1 white drain in the back (the other one to the fresh water tank is closed) but I'm just confused about this 2nd line....any thoughts?
Blubear is offline   Reply With Quote
Old 04-12-2014, 12:33 AM   #2
bikendan's Avatar
could you have one of the two low point drains open?
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 04-12-2014, 04:33 AM   #3
Blubear's Avatar
Possible...but I'm not sure. When I did the de-winterization I turned (3) knobs, in the opposite directions...hmm...is it possible that 1 of them is the low point drain?
Just all a learning process for me since I'm a "newbie"! And the whole BACKING UP INTO A SPACE, that's a comedy to watch me do ..hopefully I'll get better at it
Old 04-12-2014, 05:21 AM   #4
Water can (Drain) from many places. F/W tank vent,low point drains(2),F/W tank drain,O/S shower(2) H&C,Refer drain tube,W/H drain plug, F/W city inlet valve-if stuck, A/F pickup hose if turned the wrong way,these are just a FEW ways water can run out! Who winterized the unit? Youroo!!
Old 04-12-2014, 05:30 AM   #5
Blubear's Avatar
I did the winterization myself this past November. There doesn't appear to be any other problems but this continued leak...only when moving. It's coming from the rear...there are (2) white colored drain hoses, (1) of which has a visible on/off knob. There are (3) others to the left of the battery housing (which are right behind the water heater. I can go over and take some photos later this morning.
drain, vibe, water
