Old 09-18-2012, 01:11 PM   #11
Winnipeg,Manitoba-Canada
pdchristensen's Avatar
Originally Posted by Coal is King View Post
GVWR is 4025 lbs., from white sticker at frt lft
3500(GAWR, white sticker) + 295 (hitch wt, FR website) =3795 lbs
3316 (dry weight, yelo stkr)+692(CCC, yelo stkr) =4008 lbs
It's good there messing around with weight numbers while we're out here traveling with our families! Jeeez
My main concern is not so much the GVWR as the GAWR. At the end of the day these units only have a 3500 lb rated lippert axle & combined 3500 lb rated tires & hubs. Bouncing my single axle trailer down Canadian highways (which are no where near as well maintained U.S. freeways) will likely result in a lot of bouncing on that light weight axle/hub/tire combination. Thus my decision to upgrade the axle/hub/tire to 6,000 lbs.
2015 Rockwood 2306 MiniLite
2012 Chevy Traverse
2011-2014 - 50 nights
Paul, Darcie, Li & Yan
pdchristensen is offline   Reply With Quote
