Old 11-26-2015, 08:03 AM   #51
Dave53's Avatar
I have the 2013 HD 2500 and it pulled my 5ver no problems. With the Vibe I am stable even without the anti sway hooked up.
2016 Vibe Extreme Lite 221 RBS
2013 Silverado 2500 HD Duramax
Dave53 is offline   Reply With Quote
Old 11-26-2015, 08:41 PM   #52
Originally Posted by mopar04 View Post
I ended up cutting off and raising the LP tank platform so I could put the WD brackets at the right distance back
Could you post a picture? I have a buddy who may be able to weld something for me....
thanx!!
FerrisFamilyof5 is offline   Reply With Quote
Old 11-26-2015, 10:50 PM   #53
thanx!!
Trailer is in storage so I can't get a pic any time soon. Was an easy process though. Use a grinder to cut off the propane tank tray, then cut off the piece of angle iron going straight from left to right and replace it with 2 piece of angle iron at a 45* angle forming a V with the point aiming towards the trailer. The forward mounting point for the Tips of the V will need to be forward of where the WD bracket will sit and they taper back into a single mounting point where the Tongue portion of the trailer meets the squared frame of the trailer. Added some shims under the LP tank tray before I bolted the tray onto the new V-Shaped angle iron brace underneath it so the WD bracket could then be slid under the tank tray
mopar04 is offline   Reply With Quote
Old 11-27-2015, 09:21 AM   #54
So out 272 has the battery behind the propane tanks. We have and equalizer hitch... the hitch brackets fits fine at a proper distance without have to cut or relocate anything.
southpaw821 is offline   Reply With Quote
Old 11-27-2015, 10:39 AM   #55
Dave53's Avatar
Does anyone else have remove the v nose to hook up the we bars? The clamps are behind the cover and I replace it when the hook up the bars.
Old 11-27-2015, 10:40 AM   #56
Dave53's Avatar
Sorry spell check lol wd bars
Old 11-27-2015, 12:57 PM   #57
on my 2015 272 the battery is in the front storage. I the Equalizer is not anything like the Reese dual Cam... there are chains on the Reese setup that you have to lock in with a bracket and pins. I'm going to pick up the Equalizer sometime in the next month. Had I sold the Reese by today, I'd have gone to Canada today...they are all over here for Black Friday. It's also not a holiday for them!
Old 11-27-2015, 09:44 PM   #58
Wingdreamer's Avatar
Hi Dave, I remove my front cover when I am hooking the w/d bars onto the "L" brackets... just easier and quicker in the long run. When removing them, I just crank the front dolly leg waaaay up, then pull the bars off by hand. So, only when putting them on.
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
Old 11-28-2015, 10:25 AM   #59
Dave53's Avatar
OK thanks I have to take my nose off to hook up and unique hook. Not a big deal.
Old 11-28-2015, 10:30 AM   #60
I wonder what your set up looks like, because I do not have to take off the nose cover to hook up and unhook. The cover sits on top of the A fame.. The WD bars sit on the bracket hanging off the side of the A frame, an below the aframe. Why do you guys have to remove the cover to hook up?
vibe
