Old 06-23-2016, 11:21 AM   #1
BrianMcD's Avatar
Vibe BHS272, hose for rv antifreeze
I know it's not time yet to think about winterization, but i located my shurflo water pump was and could not find a line(hose) that would be used when putting rv antifreeze through lines in the fall. I own the BHS272 vibe, can anyone tell me how to pump RV antifreeze through the lines when the time comes. Thanks in advance.
BrianMcD is offline   Reply With Quote
Old 06-25-2016, 07:13 PM   #2
You need to purchase a bypass kit and install. Very easy to do
southpaw821 is offline   Reply With Quote
Old 08-10-2016, 01:34 PM   #3
BrianMcD's Avatar
Not with the location of the water pump, very close quarters. The height of the opening is my forearm size.
Old 08-10-2016, 01:40 PM   #4
RV Antifreeze
Brian,
Take out the bottom draw as well. I removed the panel under the oven, and the bottom drawer. That was the only I was able to get to it as well. It was a PITA but well worth the effort... The only other way would be get a hand pump and pump several gallons into the fresh tank, and use the powered pump to pull it through the system and each faucet.
Old 08-10-2016, 06:43 PM   #5
If you remove the pannel where the garbage can is and the one under the stove you can easily get to it
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
Old 08-15-2016, 10:18 PM   #6
BrianMcD's Avatar
Thanks for the replies, one more question is should i take out that metal strainer on the sureflo water pump? Guy at rv place said i should, but i dunno... Is there a reason? Thanks again in advance.
Old 08-15-2016, 10:23 PM   #7
BrianMcD's Avatar
Name:	ImageUploadedByForest River Forums1471317825.776843.jpg
Old 08-16-2016, 07:47 AM   #8
I left mine on with my last camper and this one. No issues.. but when you add.the by pass, clean out the strainer.. it will probably be fill of stuff. It is just a filter
Old 08-22-2016, 01:38 PM   #9
fireman1317's Avatar
Does anyone else just blow out their lines? I built an adaptor to connect my air compressor to my city water intake and just blow out each water line one at a time. I still bypass and drain the water heater. Afterwards I pour a cup or two of antifreeze down each drain.
2016 Vibe Extreme-Lite 315BHK
2012 F350 CCSRW 6.7l 4x4 LB
Nights camped in 2016: 26
Nights camped in 2017: ?
fireman1317 is offline   Reply With Quote
Old 08-22-2016, 01:56 PM   #10
That's what I do.
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
antifreeze, vibe
