Old 09-26-2012, 04:26 PM   #1
What are these?
there is a red and a blue line hanging down below the deck of the front of our trailer (vibe 6502). i took off a cap and water comes out. what are these for? thanks
[/SIGPIC]2012 Vibe 6502
2004 Dodge Dakota
dbuzz77 is offline   Reply With Quote
Old 09-26-2012, 04:27 PM   #2
Herk7769's Avatar
They are "Low Point Drains" to drain the water out of the lines when winterizing.
HAM CALLSIGN - KC3FFW
Old 09-26-2012, 04:29 PM   #3
does the water tank drain here too?
2004 Dodge Dakota
Old 09-26-2012, 04:32 PM   #4
Herk7769's Avatar
If you mean the fresh water tank; then no.
Look for a "petcock" under the camper connected by a hose to the bottom of the fresh water tank.
Name:	Horst Probe Install 021.jpg
Old 09-26-2012, 04:33 PM   #5
TURBS's Avatar
No
Old 09-26-2012, 04:34 PM   #6
AquaMan's Avatar
Your water tank would have a seperate drain. Usually right near the tank itself.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 09-26-2012, 04:44 PM   #7
Herk: you must have put some wood reinforcement around your water tank as I can see on your photo?
capucine is offline   Reply With Quote
Old 09-26-2012, 05:37 PM   #8
Herk7769's Avatar
Came stock with the plywood under the water tank. For the most part whoever built my 5th wheel did a pretty good job. While wires were run "helter skelter" they were at least loom'ed up with zip ties. Made trouble shooting some power problems a PITA, but they at least don't rub on anything.
Old 09-26-2012, 06:25 PM   #9
Now a "Top Member"
EdJunior's Avatar
My fresh water tank has a drain with a cap like the low point drains in your pic above. But it is separate as you said.
Ed and Sharon
2010 Wildcat 28RKBS
2011 Ford F-250 XLT, 6.7L PSD
Ride-Rite Airbags and Airlift wireless remote compressor...nice!
