Old 07-31-2015, 12:34 PM   #41
We are getting ready to purchase a Vibe 308BH. Love it and love all the features. Does anyone here have a Vibe with a ProPride 3P - if so, how did it go installing it with the front cap - did it get in the way?
DGuidry is offline   Reply With Quote
Old 07-31-2015, 04:08 PM   #42
RussellReyn89's Avatar
Thank you DocsDad! I love the layout of my Vibe completely! Really sad to hear they have decided to stop building our units. Apparently they weren't as loved as we owners love ours! I am a Kentuckian but that wasn't me with the hammer down! Ha ha! Take care and safe travels.
RussellReyn89 is offline   Reply With Quote
Old 07-31-2015, 08:09 PM   #43
Found this from Manufacturer: to reset slide, extend fully and retract about 10 inches and repeat 3 times.
http://youtu.be/hSafAnjxIV4
peasant1951 is offline   Reply With Quote
Old 08-01-2015, 08:48 PM   #44
Slide reset location
I took the panel out in the storage area and saw the slide reset box above the water heater (in the battery compartment).
Old 08-01-2015, 08:49 PM   #45
Slide reset. 2015 Vibe 6502
Old 08-05-2015, 11:44 AM   #46
wz3mo's Avatar
Love my 286RKS. It's just for the DW and me so we're enjoying all the room. Rear kitchen is perfect location and lovin' the outside kitchen too! Can't say enough good things about it. Last week camping at the lake:
wz3mo is offline   Reply With Quote
Old 08-11-2015, 07:00 PM   #47
Name:	ImageUploadedByForest River Forums1439337528.282867.jpg
ID:	85359Click image for larger version
Name:	ImageUploadedByForest River Forums1439337596.852614.jpg
Clancy vibe272bhs
timothy clancy is offline   Reply With Quote
Old 09-01-2015, 04:34 PM   #48
2013 vibe 6502
2014 toyota tundra
V6502 is offline   Reply With Quote
Old 10-03-2015, 07:48 PM   #49
Wingdreamer's Avatar
Just finished our first season with our Vibe 268 RKS, loving it!!! :
Name:	2015-05-18 14.45.13.jpg
ID:	90587   Click image for larger version
Name:	2015-06-13 19.19.41.jpg
2015 Forest River Vibe 268RKS being pulled by a 2010 F150 Lariat 5.4l, 3.73 axle Super Cab, Max Tow with 11,300 lb tow capacity , Equalizer 4 point W/D hitch
Wingdreamer is offline   Reply With Quote
Old 10-06-2015, 08:35 PM   #50
We've used our 308bhs 4 times since we received it in Aug. love it. Had to do about a dozen minor upgrades, but overall it's great
ID:	90830   Click image for larger version
Corpus Christi, Texas
TT: 2016 40' Chaparral 360IBL at 14000lbs
TV: 2016 F450 Platinum 6.7 CC LWB FX4, B&W Companion Hitch
IronCobra is offline   Reply With Quote
Old 10-19-2015, 06:31 PM   #51
@ironcobra I purchased a 308bhs a few weeks ago and this is my very first travel trailer as well as experience with one. I just recently started browsing forums for upgrades and mods. Being a newb to travel trailers, some things are going "over my head". I was just curious as to what your upgrade/mod list consist of. Thanks
lcolbya is offline   Reply With Quote
Old 10-19-2015, 08:37 PM   #52
Wellllllllll.... I have done too many mods per say. I've done the following:
1. Removed the staples that were used to Secure the trim above the couch and below the cabinets and replace them with black wood screws.
2. I removed all the screws that secured the base of the table legs into the ground slightly rotated the base and reattach the screws much more securely.
3. I installed a vent cover above the vent in the bathroom from the outside rain from getting in if I keep it open.
4. I installed a battery disconnect switch on a battery box that I put in the front of the trailer to disconnect the negative power terminal from the battery when we're not using the trailer and it's in storage
5. I put bug events on the refrigerator exhaust vent on the outside of the trailer as well as replaced the ends of the rear bumper with vented bug preventing caps
6. I went on Amazon and purchased LED replacement bulbs for all of the light fixtures which drastically decreased the amount of heat the lights put out
7. I replaced the bathroom facet with a metal looking plastic facet to match the facet in the kitchen
8. I removed the screens from both the bathroom and kitchen faucets which had little pieces of plastic that were restricting the flow of water
9. I purchased a TPMS tire pressure monitoring system for the trailers that allows me to wirelessly monitor the air pressure and temperature of the trailer tires from the cab of my truck. This will alert me to a drastic decrease in tire pressure or blowout.
10. I purchased highly reflective and UV resistant tent from Amazon and tinted windows on the RV which helps block quite a bit of heat.
11.
vibe
