Old 10-22-2014, 09:10 PM   #1
Air conditioner options???
I am close to purchasing an rood at a local dealer but I noticed they all have the slide (old style) thermostats and air conditioners with dials directly on the unit (like a window air conditioner).
Every other r-pod i see online or on the company website has the dometic digital thermostat and the air conditioner looks very different (no dials).
I see nothing about different options for air conditioning or climate controls. Anyone have any thoughts? This place sells a lot of r-pods and none of them have the AC or thermostat I see online and everywhere else. These are all 2015 models.
sponge is offline   Reply With Quote
Old 10-23-2014, 12:53 PM   #2
The digital controls have been on all models for years, and the dial controls right on the A/C were only used in the first model year (2009).
2008 FR Salem 26TBUD
2010 FR R-Pod 171 (2009-2015)
2010 Chevy Suburban
Honda EU3000is inverter-generator
techntrek is offline   Reply With Quote
Old 10-23-2014, 01:00 PM   #3
Kaadk's Avatar
It's possible that's an option that your local dealer doesn't order. If you really want it, ask your dealer if he'll do a custom order for you and see if you can get that option picked.
If he's giving you a break by buying off the lot, I'd probably just go with one that has basic wall mounted thermostat (i.e. not directly on the unit) and then swap it with a programmable one from Lowes or Home Depot or something. I believe most are compatible unless you're starting with the Dometic digital one.
Old 10-23-2014, 01:03 PM   #4
I'll add I responded with more info on the Owner's forum. Bottom line, I would be very suspicious of that dealer.
2010 Chevy Suburban
air conditioner
