Old 04-18-2019, 12:57 PM   #1
Batteries
Can I replace a size 24 house battery with a size 27 with no problems?
ChiefMo is offline   Reply With Quote
Old 04-18-2019, 01:04 PM   #2
SlowrideHD's Avatar
As long as you have room for it, or can make room, there is no problem.
2016 F350 CC Dually Powerstroke 4x4
2014 Cedar Creek 34RLSA w/Level Up
2007 HD Ultra Classic 103
SlowrideHD is offline   Reply With Quote
Old 04-18-2019, 02:23 PM   #3
electrically no problem. make sure you have room for the larger size of the group 27 and check the battery terminals to make sure they are compatible with your existing cables.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 04-18-2019, 02:31 PM   #4
Yes, yes you can. You can even use a group 31 if you have room.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 04-18-2019, 03:33 PM   #5
PPST Wannabe
kenandterry's Avatar
Quick question while you’re all talking batteries.....
I just replaced my group 24 dual cycle batteries which needed water when required, and we’re difficult to work on under the steps.
We almost NEVER dry camp, so I replaced the two batteries with maintenance free (no caps) Group 24 cranking batteries. I know that limits our staying power, but we’re ok with that.
Sound right?
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
Old 04-18-2019, 05:25 PM   #6
Trailer Park Supervisor
NJKris's Avatar
Don't draw those cranking batteries down less than 60% charged if you want them to last at all.
NJKris is offline   Reply With Quote
Old 04-18-2019, 05:59 PM   #7
Sound right?
Cranking batteries are a poor choice. They don't handle much discharge well. They are designed to crank over an engine and then get immediately charged back up. A deep discharge will kill them fast.
If you don't want maintenance, switch to an AGM battery.
2017 Coachmen 233RBS
2018 Ford F150 Lariat 3.5 Eco
"Common sense is not very common"
babock is offline   Reply With Quote
Old 04-18-2019, 06:24 PM   #8
Bigger is better.
Measure carefully the demensions of the box or boxes. Measure height. Cram that box full.
Deep cycle work best. Costco sells 2 six volts for $200. 230 or so amps.
Six volts are more durable.
How many amps you can store relates to,the volume of the battery sort of.
I always used six volts in my British cars. Gave better balance with two. Yea right, makes a difference. But, they normally lasted 8-10 years.
tomkatb is offline   Reply With Quote
Old 04-18-2019, 06:29 PM   #9
That depends. A 6V Trojan and a 12V Trojan deep discharge will have equal durability. If you look at their discharge vs capacity charts, they are identical.
Old 04-18-2019, 07:36 PM   #10
I was just on the Trojan site. Curious as I have read otherwise.
It appears to me in the signature series that 6 volt batteries generally have a double cycle life on their graph? Notice the red and gold lines and references to the individual batteries. Red is six volt. Gold, the lower one is 12 volt. 1500/3000. 40% I think.
I have read recently others state that.
On the table listing they carry similar warranty’s. 600/1200 cycles. But the curve says otherwise.
batteries
