Old 07-09-2017, 03:50 PM   #1
Battery charge??
We bought a pre owned 2015 RPod 179 a couple of months ago. The battery was not holding a charge so I figured it was shot and bought another. After sitting in driveway for a week or so , battery is dead.
What might be going on??
beckham is offline   Reply With Quote
Old 07-09-2017, 04:02 PM   #2
Flybob's Avatar
There are parasitic draws on the battery from the CO/Propane detector and the radio/DVD . These are significant enough to kill the battery in a week or two. There are three options.
1. If you have access to power, add a battery tender to keep battery charged without overcharging.
2. Plug unit into shore power and let the convertor keep the battery charged.
3. Add a battery disconnect switch or remove negative battery terminal so that battery can not drain.
You might also want to download this as a great source of info.
http://www.forestriverforums.com/for...do=file&id=101
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-09-2017, 04:31 PM   #3
Thanks so much
I feel better knowing it's a simple explanation
Old 07-09-2017, 04:35 PM   #4
Flybob's Avatar
One other caution. Be sure to check that you have not pulled the breakaway switch. Pulling the breakaway switch activates the brakes and will kill a battery in less than a day. It is easy to accidentally pull it when unhitching.
TST Tire Monitors
2 100W solar panels
battery
