Old 04-25-2016, 11:33 AM   #11
Tim347's Avatar
Camping on Battery power
Spent five days boondocking at Sleeping Bear Dunes NP, Michigan last year. Stock setup, one deep cycle battery, only mod is a battery isolation switch. I shut off the battery whenever we weren't using it, so the monitors didn't draw juice. Battery lasted, without recharging, just fine. Figured I could plug into the truck pigtail and recharge if necessary. Go for it.
Tim347 is offline   Reply With Quote
Old 04-25-2016, 11:50 AM   #12
Dave Lyon's Avatar
If the solar set up is a $1,000 as you say, not including a second battery, I'd consider an inverter style generator. At least you could run A/C if needed and you'd have back up power at home, if needed.
Dave, Southern,ON
2017 GMC SLT HD All Terrain Crew Cab (6' 6" Box) 2012 Roo 23SS
E2 Trunnion WDH (1,000 lb / 10,000 lb)
Dave Lyon is offline   Reply With Quote
Old 04-25-2016, 12:02 PM   #13
I have an awesome 100W folding solar panel that I bought for $200 that has the charge controller built in. The furnace uses around 100W by itself, so I figure that as long as I can get as much sun time during the day as I do furnace time at night, we'll be fine. We've never had an issue, even with a single battery, but we also have a generator. $1000 for a solar setup is a tad steep, unless it's 1000W and has the charge controller built into the trailer.
As for TV, if it's an LED TV, it will use a small amount of power. A non-LED LCD TV will use 2-3 times as much as an LED TV. In my case, my 32" LED LCD TV uses right under 30W.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
battery, camping, power
