Old 06-06-2017, 04:06 PM   #1
kdot's Avatar
DC question
Whenever I've had a three-way fridge, I've used AC in the campground, propane for dry camping, and DC when traveling hooked up to the trailer. My dealer tells me that the DC is intended to be used for dry camping, -just the opposite of what I've always done without a problem. What do others do? Do you use DC when towing?
kdot
2019 Flagstaff E-Pro FBS
2016 Honda Pilot
kdot is offline   Reply With Quote
Old 06-06-2017, 04:50 PM   #2
dmchapman's Avatar
The DC heater would drain your battery pretty quickly when parked. When driving the tow vehicle alternator is sufficient to run the fridge.
dmchapman is offline   Reply With Quote
Old 06-06-2017, 06:30 PM   #3
bikendan's Avatar
Your dealer is Wrong!
Equalizer WDH
Old 06-07-2017, 11:04 AM   #4
Head Rambler
Amen to this. Running on 12 volt DC would drain a good bank of batteries pretty quickly. Most of those DC elements draw about 15 amps when running.
Gotta go campin!
Old 06-07-2017, 11:47 AM   #5
Dealer's wrong. Assuming your fridge is a Dometic, I got this Caution from a Dometic RM8501 manual:
CAUTION
The refrigerator should only be used in
12VDC-operation while the vehicle’s engine
is running, otherwise the on-board-battery
would be discharged within a few hours!
Read your manual, ignore the dealer; they are notoriously ignorant and mis-informed.
If you don't have the manual, you can find it here:
http://www.dometicmanuals.com/PROD/M...f?Opendatabase
2011 Traverse LT, 3.6L, FWD
Old 06-08-2017, 04:57 PM   #6
kdot's Avatar
Thanks again. I just completed a 400 mile trip to and from Bayfield,WI and ran the fridge on battery all the time I was driving. Nooooo problem whatsoever.
Kot
2016 Honda Pilot
Old 06-09-2017, 08:46 PM   #7
So new here...have a new to us 2010 Rpod 172. Does the trailer hookup provide +12 to the Rpod to power the fridge?
flyinghigh is offline   Reply With Quote
Old 06-09-2017, 08:50 PM   #8
Flybob's Avatar
Yes. It will power the fridge while driving, but be careful if your vehicle does not have an ignition operated relay in the circuit it will kill the TV battery if left connected while parked for any length of time. Note the TV will assist the rpod battery in running the fridge and not much more.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 06-10-2017, 12:28 PM   #9
Don't assume your vehicle 7 way is wired for 12 volt through put. It may be and it may not be. Test is with a volt meter first.
2011 Flagstaff 831FKBSS
2010 F250 4X4 5.4L 3.73 LS
EQUALIZER E4 1200/12000
Old 06-11-2017, 01:50 PM   #10
Thanks...will do!
