Old 08-05-2016, 10:17 AM   #1
Dual battery install steps?
I'm going to add a 2nd battery this afternoon and I was hoping to validate that my logic is right. I'm planning on:
1. Disconnecting the positive trailer lead
2. Disconnecting the negative trailer lead
3. Running a jumper from battery #1 negative to battery #2 negative
4. Running a jumper from battery #1 positive to battery #2 positive
5. Reconnecting trailer negative to battery #1
6. Reconnecting trailer positive to battery #2
Sound right?
Jeepin_182G is offline   Reply With Quote
Old 08-05-2016, 10:24 AM   #2
It depends if you are using 2 12 volt or 2 6 volt
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 08-05-2016, 10:26 AM   #3
dan-nickie's Avatar
1. Disconnecting the NEGATIVE trailer lead
2. Disconnecting the POSITIVE trailer lead
5. Reconnecting trailer POSITIVE to battery #1
6. Reconnecting trailer NEGATIVE to battery #2
Sound right?
This slight change keeps you from accidentally touching your wrench to the frame ground while connecting/disconnecting the Positive terminal. Which would cause a spark and possible explosion.
ETA: since you state 'adding a second battery' I assume your current single battery and the additional battery are both 12 volt.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 08-05-2016, 10:29 AM   #4
Sound right?
correct, I will add that the batteries should match, meaning same size and same age.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2018-16) (2017-16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 08-05-2016, 10:30 AM   #5
Would be a 2nd one of these
Name:	ImageUploadedByForest River Forums1470411024.802874.jpg
Old 08-05-2016, 11:54 AM   #6
Thanks for the input SiicideSaints. I was able to get the same size battery. As to the age, the current trailer battery was only used during the drive home from the dealership and then it was connected to the TV so it's practically new.
Old 08-05-2016, 12:22 PM   #7
you should be just fine then
Old 08-05-2016, 12:52 PM   #8
Ham Camper's Avatar
To join batteries in parallel, use a set of cables to connect both the positive terminals and another set of cables to connect both the negative terminals of both batteries to each other. Negative to negative and positive to positive. You then connect your load to ONE of the batteries, but both drain equally.
Larry W8PO & Lori N8IHJ and Louie the wonder dog
2014 Surveyor Cadet 265RLDS
2015 GMC Denali HD
Ham Camper is online now   Reply With Quote
Old 08-05-2016, 01:16 PM   #9
CaptnJohn's Avatar
I would add a shut off also. The shutoff that is standard on the trailer still allows a lot of drain.
2019 Montana 3761 FL
2019 F350 6.7 4X4 LB Dually
Edgewater 205 EX 150 Yamaha
Old 08-05-2016, 01:32 PM   #10
bikendan's Avatar
Google "12 Volt Side of Life "
Equalizer WDH
battery
