Old 05-14-2018, 03:14 PM   #1
Faucet wonít shut off in bath area
There appears to be no problem with the hose, but water runs from the faucet. Iíve taken it apart, but canít figure out how to remove the valve. There is also a leak where the water connects to the toilet. Canít understand why there are no shut off valves in rvs! Any suggestions?
Jim Black is offline   Reply With Quote
Old 05-14-2018, 03:19 PM   #2
Is this the 1st time out after Winter? Youroo!!
Old 05-14-2018, 03:20 PM   #3
cavie's Avatar
Remove the RV plastic junk and go to HD/Lowes and get a better one for about $25-$35.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-14-2018, 03:21 PM   #4
1st post... Welcome!
Sounds like maybe you've experienced some freeze issues?
Both the faucets and the toilet valve are prime issues for cracking.
Installing shut-offs would add cost. Even though very little, you won't get anything 'extra' that would make any sense on today's R/V's.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 05-14-2018, 04:10 PM   #5
Yes, itís the first time in three years! The previous owner used it once. She said she didnít use the water system, but I suspect the dealer had tested it and not adequately drained it since it was purchased in the spring.
I would like to teplace it with something better, but had better get a plumber as I donít have the tools for this kind of pipe.
Old 05-14-2018, 04:23 PM   #6
Keystoner's Avatar
You shouldn't need a plumber, unless adding shutoff valves and even so you could use Sharkbite slip on fittings, for the shut offs. (I've not used them) The faucets and pipes use threaded fittings.
I've replaced both my bath and kitchen faucets with Moen that were in sale. Simply unscrew, swap, screw tight.
ID:	171828Click image for larger version
Keystoner is offline   Reply With Quote
Old 05-15-2018, 01:46 PM   #7
Usually...
Yes, it’s the first time in three years! The previous owner used it once. She said she didn’t use the water system, but I suspect the dealer had tested it and not adequately drained it since it was purchased in the spring.
I would like to teplace it with something better, but had better get a plumber as I don’t have the tools for this kind of pipe.
Usually you don't need any tools. Hand-tight on the fittings is enough. (You usually don't need a wrench to tighten the mechanical mounting on the faucet either.
Look at this picture:
Two big plastic nuts screw up the outsides of those threaded brass tubes to hold the faucet to the sink. Hand tight or maybe a little help with a pliers. You shouldn't be able to move the faucet around on the sink.
Then two white plastic cap-nuts (already on the plumbing in the trailer) screw onto the ends of those same threaded tubes. Hand tight is good enough. Be sure to mark the tubes before you take them off the old faucet. Hot is on the left.
Take a good look at the bottom of the faucet you have--maybe take some cellphone pictures--and make sure the new one looks the same.
Larry
Larry-NC is offline   Reply With Quote
Old 05-15-2018, 08:53 PM   #8
Thanks so much! I canít believe how helpful you all are. I bought a new faucet and will give it a go tomorrow.
Old 05-16-2018, 12:06 PM   #9
Shut Offs
The pump or the external water supply IS the shutoff.
Like others have said; new faucete are cheap and better from Lowes, Home Depot
pdqparalegal1 is offline   Reply With Quote
faucet
