Old 04-09-2016, 10:15 AM   #1
Heater
First time we camped in our new Pod, we needed the heat! Crazy weather. Turned on the furnace and the overhead unit came on. And we could feel the heat coming from under the bed. Curious why the overhead unit came on?
We are planning on camping without electric service. Can we still run the furnace and not have electric service to the Pod?
Thanks!!
Bernie 2016 RPod 179
K4JDF is offline   Reply With Quote
Old 04-09-2016, 10:26 AM   #2
SeaDog's Avatar
Your furnace should run provided you have propane and 12V power
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-09-2016, 10:29 AM   #3
Flybob's Avatar
You don't say what thermostat you have. If it is the Dometic, set it to auto, not hi or low and only the furnace fan will come on. The furnace fan and controls are all 12V so yes if you have propane you will have heat when not connected to shore power. One word of caution. The fan uses a reasonable amount of power so you will have to charge the batteries often depending on how much the furnace runs.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-09-2016, 12:26 PM   #4
bikendan's Avatar
Just remember, furnaces are the biggest consumers of your 12v battery power.
If you have a single 12v battery and no electric hookups, running the furnace all night can completely drain the battery by morning.
For dry camping or boondocking, you really need a minimum of two deep cycle batteries and a way of recharging them, either by generator or solar panels.
And don't expect your tow vehicle to recharge a drained battery. You would need to drive for hours to do that.
Equalizer WDH
Old 04-14-2016, 09:53 AM   #5
Thanks!!
Thanks to all who responded to my question.
heater
