Old 09-21-2011, 11:17 AM   #1
Help with RPod 171 Air conditioner fan
We just bought a 2012 R Pod 171 and took it out for the first time. We had the thermostat set to furnace and the furnace worked great but when we turned the generator on the air conditioner fan came on and would not go off until we pulled the breaker on it. Does anyone have any suggestions on how to fix this problem? Thanks for the help
Reggiesmom is offline   Reply With Quote
Old 09-21-2011, 01:59 PM   #2
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
There is usually a switch on the thermostat that allows you to select Auto or Run for the fan. On Run the fan will always be on. On Auto it will cycle with the AC/furnace.
dimurrrw is offline   Reply With Quote
Old 10-01-2016, 11:02 AM   #3
TIKIPOD's Avatar
Our 2011 rpod 177 hvac unit has a Domestic thermostat. It has options of fan, cool, or heat. There is NOT an "Auto" selection. How can I get the fan to stop running in the A/C when I only want the furnace to work?
TIKIPOD is offline   Reply With Quote
Old 10-10-2016, 07:03 PM   #4
Select Fan. Fan has three settings, High, Low, and Auto. Set to Auto, then select Heat.
johnbryanpeters is online now   Reply With Quote
air conditioner, fan, r-pod
