Old 07-13-2017, 12:46 PM   #1
How do you keep the hot water from smelling?
Out for our first week in the Rpod 172. When we are gone for a full day, the water out of the facet smells when we first run it (hooked to city water supply)
If you run the cold water for a few minutes, once the lines are empty it is fine. However, you can run the hot water (even if the heater is off) forever and it keeps smelling....I am guessing it will smell until we empty the entire hot water tank? How large is that?
Any other options to solve this? Thanks in advance!
flyinghigh is offline   Reply With Quote
Old 07-13-2017, 12:51 PM   #2
fonzie's Avatar
Either it is the water at the location you are or you need to sanitized the whole system with bleach.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 07-13-2017, 12:53 PM   #3
wmtire's Avatar
Check out video #5 at this link below to see if that may help and/or be the cause:
Suburban Water Heater Video Guides
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 07-13-2017, 12:53 PM   #4
Guessing I need to sanitize...since it does not smell if I run enough of it.
Sanitizing sounds complicated...
Old 07-13-2017, 12:59 PM   #5
wmtire's Avatar
Not really, it's explained in the link I posted above.
Old 07-13-2017, 01:01 PM   #6
Thanks folks, I will review both and try to rectify. Much appreciated!
Old 07-13-2017, 01:02 PM   #7
Fulltime family RVer
Nah, it's pretty easy. I did it at a campsite last year and actually need to get to doing it again.
Here's how I did it:
Eww, stinky water! Sanitizing the fresh water system. | Learn To RV
Old 07-14-2017, 01:26 PM   #8
We had that problem years ago. Never after we started to use the pretty blue water filter. No more smell. We use the filter always for any water going into the coach, either directly or through the storage tank, home, away no matter, everything is filtered.
Sandy B is offline   Reply With Quote
Old 07-14-2017, 01:28 PM   #9
Good to see you back posting Doug!
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 07-14-2017, 01:29 PM   #10
W5CI's Avatar
Just drain and flush your hot water heater, that will take care of it
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2017 Days Camping 77
2018 Days Camping 44
W5CI is offline   Reply With Quote
hot water, water
