Old 04-28-2017, 07:45 AM   #1
Unhappy Jensen Stereo
Certainly not a big problem, but I read somewhere that there is a way to turn off the clock, that is the lights on the stereo (JWM6A) as it is one of the things that is a drain on the battery when not hooked up to shore power and also because its a bit bright and annoying -especially in the middle of the night. Any help would be appreciated.
Michele and Douglas is offline   Reply With Quote
Old 08-21-2017, 01:13 AM   #2
My Jensen JCD2010 has three wires that deal with power. A heaver gauge yellow wire labeled +12VDC Battery (Memory), a light gauge orange wire labeled illumination/dimmer, and a light gauge red wire labeled +12VDC switched (ACC).
Apply full time power to only the yellow +12VDC Battery (Memory). Put the other two wires, the orange and red wire on a switch. Doing this saved 45mA of parasitic power draw and shuts off the illumination.
2016 Coachmen Viking Legend 12RB A-Frame
2015 Jeep Grand Cherokee Summit w/Tow package
Alben is offline   Reply With Quote
Old 08-21-2017, 08:03 AM   #3
The liquid crystal display (LCD) panel (1) displays the frequency, time and activated functions. To adjust the brightness of the LCD, press the BRIGHT +/- buttons (2) to adjust the LCD brightness from “LEVEL OFF” to “LEVEL 9” (brightest).
Instructions link, see page 4.
http://www.jensenrvdirect.com/downlo...ers_manual.pdf
mcarter is offline   Reply With Quote
Old 08-21-2017, 08:40 AM   #4
Señor Member
ForestWalker's Avatar
Audio/menu button
JWM6A QUICK REFERENCE GUIDE
2017 Forester
3051S "Bluga"
ForestWalker is offline   Reply With Quote
Old 08-21-2017, 10:49 AM   #5
PhD, Common Sense
We installed a battery cut-off switch. Only way to keep detectors from vampiring batteries to death. That will solve your problem too.
eye95 is offline   Reply With Quote
Old 08-26-2017, 05:55 PM   #6
PhD, Common Sense
That was a silly reply on my part. You meant while camping without shore power.
jensen, stereo
