Old 03-29-2015, 08:03 PM   #1
Manual override of rpod 179 slideout
I bought a 2015 rpod 179 yesterday. How do I manually override the slideout in case of failure? Where is the slideout control panel access? Thanks.
TooFatLadies is offline   Reply With Quote
Old 03-29-2015, 08:16 PM   #2
kymooses's Avatar
I have PDF of it I could email you if you want to send me a message here.
I think if you just google Schwintek manual over-ride you'll end up finding it for download somewhere.
Travis & Carrie
181g - MoosePod Adventures Map
RPod Owners Map
kymooses is offline   Reply With Quote
Old 03-29-2015, 08:17 PM   #3
HONDAMAN174's Avatar
Look underneath for the slide motor. Should be a "nut" where you can put a socket on and crank the slide open or closed manually.
2014 Stealth Evo 2850 "Woodstock"
2011 Toyota Tundra Rock Crawler TRD 5.7 "Clifford"
Just glad to get away
Old 03-29-2015, 08:21 PM   #4
kymooses's Avatar
Different type of slide on these models.
Travis & Carrie
RPod Owners Map
Old 03-29-2015, 08:35 PM   #5
Thanks. I found the Schwintek manual online. I don't know if or where the control panel access location is though on the 2015 rpod179. Does anyone? Thanks much!
Old 03-30-2015, 08:05 AM   #6
kymooses's Avatar
The control panel will be beneath the ottoman under a screwed down lid. Did you read the part where you would need a brace to hold the slide in once you disengage the motors if you had to push it in this way?
Travis & Carrie
RPod Owners Map
Old 04-01-2015, 10:00 AM   #7
Doll House Two
R Pod 179
I own an RP179 also. I find the the R Pod forum ( separate from this Forest River site ) is very helpful. Happy trails,
Doll House Two is offline   Reply With Quote
manual, slide, slide out
