Old 07-24-2015, 04:08 PM   #1
Mounting screws
I am installing a mini blind in my 179. Should I use the plastic anchors or just the screws to attach the brackets
pmorris1 is offline   Reply With Quote
Old 07-24-2015, 04:18 PM   #2
Flybob's Avatar
anchors and short screws. Drill a small pilot hole first, then check to see if there are any wires etc where you will be putting screw. Once you ae comfortable there is nothing there, use wall anchors and short screws.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-24-2015, 04:36 PM   #3
Thanks for the info. I am not sure how thick the panel is in my rpod wall. I would guess one eighth thick. Would a miniature Molly bolt or the plastic anchor with screw work better
Old 07-28-2015, 05:57 PM   #4
kymooses's Avatar
It's 1/8" as you suspected. Unless it's something absurdly heavy there's no reason to not just use a small screw. Your valences and the mini blind brackets that used to be in the older Pods before the Nightshades are just screwed right into the wall directly.
Travis & Carrie
181g - MoosePod Adventures Map
RPod Owners Map
kymooses is offline   Reply With Quote
mount
