Old 01-12-2019, 02:01 PM   #1
New, Please Help
Hello and peace be to the forum. I am new to all of this. I am a disabled veteran and after evaluating many different options it seems that a travel trailer is my best solution. I need a place to live/stay on the grounds where I work. Traveling to and from where I work is getting to be too much and so I have been given permission to have a travel trailer on the land where I work (agriculture zoned). So I am going to trade in my current car for a 2016 Chevy Colorado Z71 and then go and get either a 2018 or 18 Rpod. Not exactly sure which model but I am looking at the 179. My initial questions for the forum are these:
1. Comments, questions, concerns, etc. about the 2016 Chevy Colorado Z71 pulling the R-pod? The Colorado Z71 has a 3.6L SIDI DOHC V6 VVT ENGINE and a 6-SPEED A/T. If more information about the Colorado is needed then let me know and I can provide it.
2. What exactly will I need to pull the R-pod home from the dealership and to the property where I will be living? In other words, the Colorado has a trailer hitch but I do not know what size ball I will need? Will I need to purchase some kind of wiring harness or does that come with the R-pod?
3. What else would I need to make this work? What am I overlooking?
There is power and water for the travel trailer at the work site where I will be living. I am going to use a portable septic initially until a permanent one can be put in place.
Please help me. I am sure there are many things I may not be taking into consideration here. I have done some research but I think I trust the information on this particular sub-forum about R-pods than some of the "at large" information I have found on the interwebs.
My set-up is not initially for RV-ing as I will be living in one place with the R-pod primarily. Sure, on occasion as time and vacation permit I would like to "get out there" and do some camping; but initially I am just concerned about getting the R-pod safely from the dealership to where I will be living in it. I believe that distance to be traveled is about 70 miles.
Any and all information is greatly appreciated. May God reward your charity. Thank you for your time in advance. God bless you!
divinewillhermit is offline   Reply With Quote
Old 01-12-2019, 02:26 PM   #2
Head Rambler
1) The Colorado is either rated to tow 3500 lbs r 7000 lbs depending on whether is has the tow package. The R-POD has a GVWR of about 3800 lbs with a dry tongue weight of about 300 lbs, so you'll either be fine or a little over tow rating.
2) For just the trip home from the dealer you'll probably be fine just towing it on the ball. I'm not sure what size coupler the R-Pod has, so you'll need to find that out. The R-Pod comes with an umbilical cable that will operate the required lights and brakes.
3) If the Colorado has the towing package, it will have a 7-way trailer connector that the plug on the R-Pod will plug into. You'll need a brake controller if it doesn't have one.
Gotta go campin!
Old 01-12-2019, 02:47 PM   #3
2” ball.
masonboswell is online now   Reply With Quote
Old 01-12-2019, 03:04 PM   #4
I can’t help with the Rpod questions but one of our work vehicles is a 2016 Colorado 4 door, long box with the 3.6l engine and I personally own a 2016 Silverado double cab with the 5.3l V8.
My Silverado turns easier, rides better, has tons more room, gets about the same mixed mpg and maybe 1-2 less on the highway and cost the same to buy it so be sure the Colorado works best for you. I don’t mind the Colorado but honestly it feels just like my old ‘95 S10 inside and the Silverado is a much better vehicle in my experience.
Thanks for your service and I wish you well in your endeavors.
Current:
2019 Rockwood Roo 24ws
2016 Chevy Silverado Z71 4x4 DC
Past:
2001 Starcraft Spaceliner PU
1987 Starcraft Nova PU
Miweber929 is offline   Reply With Quote
Old 01-12-2019, 03:58 PM   #5
I towed with a 2016 Colorado 3.5, w/tow package. The ball is 2", with the tow package you will get a 7 pin connector. You will need a brake controller on the road, the P3 Tekonsha is great but has to be wired in. Would advise a sway bar for open road. I have a 178 and towed with a Colorado for over a year if you have any further questions. To be honest on day of purchase I towed it home with standard 2" ball, no brake controller, no sway. 7 pin connected, check with your dealer, some states have requirements on weight and brake controllers before you tow. The dealer can install and give you operational advice.
mcarter is offline   Reply With Quote
Old 01-12-2019, 05:58 PM   #6
Hello and thank you for taking the time to reply to my question.
Would this be correct? Would I need a brake controller still? I have towed things before but to be honest I do not think I have ever had or used a brake controller?
Old 01-12-2019, 05:59 PM   #7
Originally Posted by masonboswell View Post
2” ball.
Thank you. I believe I have one already. Thanks be to God it is a 2" I need. God bless you.
Old 01-12-2019, 06:01 PM   #8
Thank you for taking the time to reply to my question and share your advice and experience. I was actually thinking the same thing when I also looked at I believe a 2016 Silverado. I may have to revisit the Silverado.
Thank you for thanking me for my service. I thank God for giving me the courage to have served. God bless you.
Old 01-12-2019, 06:06 PM   #9
Thank you for taking the time to reply to my questions. Your answer is very thorough.
Some follow-up, if I may: So if I understand you correctly; on the day of purchase and for me driving it "home" should I need anything in addition to what the Colorado already has (see picture of the rear bumper I have included in another thread)? I am in the state of Florida if that would help you answer my question regarding whether I will need this brake controller.
Also, when you say "the dealer can install and give you operational advice" are you referring to the Chevy dealer or the R-pod dealer?
I am trying to have all of the information "in hand" before I go next week because I often forget to ask things and people often take advantage of me because of my disability. So any additional information/advice you can give would be greatly appreciated. God bless you.
Old 01-12-2019, 06:28 PM   #10
Also, just as another option: can I rent a U-Haul truck and bring the R-pod "home" to the property I will be living on? If so, would the U-Haul have all of the necessary things i.e. brake controller, panel to plug the R-pod's umbilical cord into, etc.?
