Old 06-09-2016, 10:00 PM   #11
karenhanson's Avatar
I'm thinking that could be it as well. It could have been damaged when the bracket was replaced. I'll try that when we get back home and see if that takes care of the problem.
karenhanson is offline   Reply With Quote
Old 06-09-2016, 10:16 PM   #12
Rupkin2's Avatar
Originally Posted by bob caldwell View Post
My vote would be for a bad coax cable end at the tv.....I'd cut it off and replace the end...or, if there's a 90 degree coupler there, temp. by-pass it..
Is that possible?(Cable end I mean not the 90). Why would some channels come through but not all of them?
Usually with cable when you get one you get them all.
May as well try it, either that was it or its elimanated.
With only 8 channels at 2 camp sites I'm thinking maybe only your antenna is receiving channels and somewhere it's not switched to cable.
Is there a antenna/cable switch somewhere?
I'm grasping at straws here.
Oh, I just thought, some TVs have 2 threaded connections at the back. One is CATV and the other is an out to a component. Make sure your coax is in the CATV. More straws.
John
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 06-10-2016, 01:23 PM   #13
Retired Member
rmwmiata's Avatar
We go to one campground that supplies cable where main tv will program but bedroom tv needs one of their converter boxes.
rmwmiata is offline   Reply With Quote
Old 06-10-2016, 01:50 PM   #14
Left Coast
Need newer tv...
Bob/Linda, 99 Dodge 2500 Cummins,2010 8280 Rockwood Ultra-lite 5er, PullRite Superglide----- I'm retired......but work part time as a pain in the ass!........... USMC.
bob caldwell is online now   Reply With Quote
Old 06-10-2016, 04:13 PM   #15
Ok today we got to a new campground and I tried to get the cable to work. Still no luck. This time I bypassed the interior cable hook up and used a different coax cable that I know works. Connected it to the wall and to the TV. Still can't get the correct cable channels. For some reason it is still only pulling from the antenna. It's almost as if it needs a reset to pull through cable channels.
Old 06-10-2016, 04:17 PM   #16
Pod2Vibe's Avatar
Year and model of the Rpod? I used to have one and would like to help.
I recall there being two coax connections behind/above the TV, one for SAT and one for Cable. Maybe try swapping.
Pod2Vibe
2015 Solera MBS 24R - Hellwig/Sumo Equipped
TOAD: 2014 Fiat 500 Abarth
(Sold the Vibe 6506)
Pod2Vibe is offline   Reply With Quote
Old 06-10-2016, 04:32 PM   #17
Left Coast
And the TV is set for cable....? How about hooking up from pedestal direct to TV, and not using any other cable....skip trailer wiring for now...
Sent from my XT1585 using Tapatalk
Old 06-10-2016, 04:32 PM   #18
DAISY BOYKIN's Avatar
cABLE CONNECTIONS
Do you have a 90 elbow on the back of the TV where the cable connects to TV? I had a problem with mine where it was the 90 elbow was bad. A small wire in the elbow was broken. Lowes carries the elbow.
Try removing the elbow, connect the coax direct to the TV.
Sid, Lois & HRH MISSY Terrible 2s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS/SD/6R140/BFT
BOLIY PRO 3600SI GEN
DAYS CAMPED 2016 74 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-10-2016, 04:33 PM   #19
Left Coast
Some TV's can be reset by disconnecting power cord for a few minutes.
Old 06-10-2016, 04:33 PM   #20
Herk7769's Avatar
To switch between Antenna and cable you must find the power supply/source switcher button on the wall plate.
Push till power light comes ON -> source is roof antenna
Push till power light goes OFF -> source is cable TV
Once you have selected a source; you still need to search for channels.
HAM CALLSIGN - KC3FFW
