Old 06-11-2016, 06:51 AM   #21
Originally Posted by rmwmiata View Post
We go to one campground that supplies cable where main tv will program but bedroom tv needs one of their converter boxes.
rmwmiata
Seiki TV in bedroom I bet. Seiki TVs lack a decent tuner to receive cable from some providers. Therefore some campgrounds it is not usable at others it perfectly OK But this doesn't t help the R-Pods problem
twoclaws is offline   Reply With Quote
Old 06-11-2016, 07:12 AM   #22
Retired Techie
There is a short coax jumper that must be installed between two ports for cable to work. Should be close to antenna switch.
2005 Wolf Pack WP22-2016 Grey Wolf 26RR-Gone
2004 Siverado 2500HD Duramax
2013 Keystone Springdale 5r
1998 Honda Valkerie
2016 Camping 148 days so far
moligney is offline   Reply With Quote
Old 06-11-2016, 08:46 AM   #23
Retired Retail/Importer
Antenna cut off where is it?
I picked up our 2017 360PDEK at Jeff Couch RV Nation in Hamilton OH...last week...the TV's were set up and worked perfectly...The walk through guy told me it was on antenna and I'd need to turn that off when I use cable...BUT he never could find the place to turn it off...I'm in a campground in The Smokey's and can't get cable to work...Anyone know WHERE the cut off is?...It's ridiculous that we even want TV but it does have 4!!! and I wanted to watch the news last night...
pledbetter is offline   Reply With Quote
Old 06-11-2016, 09:07 AM   #24
Left Coast
Where the coax cable is attached to wall plate......push button and led light......light on is ant., light off is for cable
Sent from my XT1585 using Tapatalk
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 06-11-2016, 09:09 AM   #25
Left Coast
Then go into TV menu and select cable
Old 06-11-2016, 09:34 AM   #26
Cable
All TV's are hooked up where the cable is behind them...I see nor could I feel any button also, I looked and there's no light visible behind them???? Where the cable comes in from the campground, I've screwed that coax into the camp cable in...
Old 06-11-2016, 09:48 AM   #27
Rupkin2's Avatar
For what ever reason I'm would say you are only getting a signal via the antenna and not the cable.
The initial problem started AFTER the wall mount had been replaced. I would think that everything from the wall connection and beyond should be ok, unless you experienced a power issue at the time of switching.
I would revisit the tv area where the brackets are. Something has change here. Maybe get a friend to have a look. I know myself during troubleshooting after awhile one can become blind to the obvious.
You have got me quite curious on your delema here. To bad I couldnt be there in person, it would make this easier.
Please let us know when you get this resolved.
John
PS i am sending this from my phone. Bound to be tpyos.
07- Classic 2500 LT CC 4x4 SB Duramax/Ally
13-320RLT Crusader TE
Reese 16K Kwik Slide/Prodigy brake contoller
Rupkin2 is offline   Reply With Quote
Old 06-11-2016, 09:57 AM   #28
TV Cable
I just remember the walk through guy Bob, told me the antenna next to be off for the cable to work...The TV's were working great at the dealership on antenna...only thing is, he couldn't find the switch and I forgot to press the issue as there were so many things to go over. There is a flat rocker switch on the wall near the monitor board that we can't figure out what it does...geech It's something simple I know...just can't see to figure it out
Old 06-11-2016, 10:08 AM   #29
Left Coast
Go to main TV....wall plate has coax that goes to TV.....on that wall plate is the antenna booster ....that plate has the button on it.....only wall plate that does....nothing on tv's
Old 06-11-2016, 10:12 AM   #30
Left Coast
Wall switch could be inside cabinet
