Old 08-04-2016, 04:54 PM   #1
R-Pod Bolt Pattern?
Can anyone confirm the bolt pattern on a 2016 pod. Google searches keep coming back with 5x4.5 but when I put the tape measure to it, I swear it's 4.25 but the center cap makes it difficult to be exact.
Jeepin_182G is offline   Reply With Quote
Old 08-05-2016, 09:12 AM   #2
Head Rambler
Are you measuring bolt to bolt? If so, that measurement is going to be a little less than the bolt circle diameter because the bolts aren't exactly across from each other.
Measure the distance between the centers of adjacent lugs. If it's 2-5/8" then it's a 4Ĺ" bolt circle.
5x4Ĺ is the standard bolt pattern for most trailer wheels. For some trivia. It's the bolt pattern of the Ford Ranger wheels.
Gotta go campin!
Old 08-05-2016, 10:11 AM   #3
Thanks for confirming Bama. I wasn't aware of the adjacent measurement option and the center cap made eyeballing it difficult.
The 5x4.5 is also the 87-06 wrangler bolt Pattern so lots of options.
