Old 10-16-2015, 12:48 PM   #1
R-POD HW Heater Bypass Winterizing
Do the R-PODs have the BYPASS feature on their Hot Water Heaters?
gypsypup is offline   Reply With Quote
Old 10-19-2015, 04:57 PM   #2
Yes.
Just used mine while winterizing.
SeaFractor is offline   Reply With Quote
Old 12-08-2015, 10:07 PM   #3
Where?
We couldn't find it.
Bill
Poohbill is offline   Reply With Quote
Old 12-09-2015, 11:06 AM   #4
kymooses's Avatar
Bill
Wherever your water heater is on the outside you'll find it under whichever compartment is on the inside of your Pod in that same location.
Usually under beds, or the dinettes.
Travis & Carrie
181g - MoosePod Adventures Map
RPod Owners Map
kymooses is offline   Reply With Quote
Old 12-09-2015, 01:09 PM   #5
I'll take another look in the spring. Why would the water heater have any connection to the gray water system, such that a bypass would be needed before pouring antifreeze down the drains?
Sure wish for schematics on the systems!
Old 12-09-2015, 01:13 PM   #6
Any water from the water heater would go thru the sinks, shower, etc and drain into the grey water tank.
Old 12-09-2015, 02:45 PM   #7
Antifreeze getting into HW tank
From my reading, the bypass valve was so the antifreeze poured into the drains didn't get into the HW tank. I just can't see how it could.
Old 12-09-2015, 03:38 PM   #8
BooBoo23's Avatar
The bypass is to prevent filling the HW tank when you winterize with RV antifreeze. The HW tank should be drained for winterizing by removing the anode rod (good time to examine the anode for wear) and opening the relief valve to drain rapidly. Open your low point drains (should be a note on the side of the TT where they are located). The bypass valves are located on the back side of the WH tank.
If you don't know how to winterize a RPod I suggest you look at any of several You Tube videos on the subject and they should tell you how it is done.
2014 Palomino Puma 25RS
2011 F-150 Super Crew XLT
Days camped in 2014 - 23 Camped 2015-47
Camped 2016-71, 2017-33, 2018-29 booked
KT4W
BooBoo23 is offline   Reply With Quote
Old 12-09-2015, 04:25 PM   #9
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 03-14-2016, 01:47 PM   #10
rpod 179; while checking out my hot water heater: I took the bed off and plywood. I needed extra length in the storage bin for my 6' ladder so I took off the section in the back left by the water heater. Is there any issues about doing this?
ID:	101915   Click image for larger version
ID:	101916   Click image for larger version
jglynn55 is offline   Reply With Quote
bypass, heater, winter, winterize
