Old 08-22-2016, 09:52 PM   #1
Rdome Issue
Have a new 179 Rpod and Rdome. On Rdome, rubber on tubing that connects to C channel softens in sun, loses rigidity and comes out of C channel every day. Came back from beach and complete awning had collapsed. Any ideas how to fix? I've never had an $800 tent not live to expectations. Doesn't help that the suction cups on sides often lift off, causing more torqueing on dome.
Marcinmiddleton is offline   Reply With Quote
Old 08-23-2016, 07:24 AM   #2
kymooses's Avatar
You'll need to replace the suction cups that came with it with betters ones. You can find some great replacements actually at Walmart or Lowes. I believe the brand is Interdesign Power Lock. Mine won't pull off in a big storm.
As far as the dome sliding out of the track you'll need to crimp the C-Channel some at the parts that it is slipping. It's just a bit big at those points. Some vice grips and a towel so that you don't scratch the channel and just close the C a bit so that it won't slide out anymore.
Travis & Carrie
181g - MoosePod Adventures Map
RPod Owners Map
kymooses is offline   Reply With Quote
