Old 05-08-2019, 08:33 PM   #1
Re: leaving Pod at RV park during the week
Hello-
Were planning on taking the Pos to a campsite for a couple of week, but will just be using it on weekends.
Typically we plan on getting there Friday and leaving on Sunday..questions are, when leaving the Pod for the week, Im assuming we leave it plugged in, fridge and all, but what about the tanks..do we flush both or just leave them for the week and flush upon returning?
If so, would you shut the water going to the camper?
Thank you
RVngFam is offline   Reply With Quote
Old 05-08-2019, 08:44 PM   #2
B and B's Avatar
Flush before leaving best idea. No Stinky on Return and no harmful chemicals to overcome a wee of decaying waste in the tanks.
Go Green!!
Old 05-08-2019, 09:15 PM   #3
Oaklevel's Avatar
I would shut the water off. The sun could burst the hose or.....A leak or other failure is possible and may be a mess upon your your return. I know a few people that turn the water off if they were only gone a couple of hours.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 05-09-2019, 08:47 AM   #4
RedLdr1's Avatar
I'd empty both tanks and flush the black tank... Then add five gallons of water and a chemical pack to the black.
As far as leaving it connected to power that shouldn't be an issue. Our last motor home was plugged in to shore power all the time in storage. I'd be a bit nervous about leaving an external power protection device hanging out for a week.
I always turn off the water if we are going to be gone any length of time. I had the small clean water hose come off a toilet and flood the rear of a trailer. I came back to a nice waterfall coming out under the door and down the steps...
Wayne and Christine
2019 R-Pod RP-180 10th Anniversary Edition
2018 Ford F-150 SuperCrew Lariat FX4 (4X4) 3.0L Power Stroke Diesel
RedLdr1 is offline   Reply With Quote
Old 05-09-2019, 07:31 PM   #5
I would shut water off and turn water heater off. Also turn circuit breakers to only what is needed. Waste tanks I would monitor and dump as required. It doesn't seem productive to dump 1/4 fill tanks. BTW - secure the trailer, ball locks and such. Put your campsite stuff away.
mcarter is offline   Reply With Quote
Old 05-14-2019, 06:50 AM   #6
Water
I ALWAYS shut off water, when leaving RV alone. SOP for me.ESPECIALLY if the campground warns you of high water pressure, when you check in.
twdenman is offline   Reply With Quote
