Old 04-25-2016, 11:47 AM   #1
Tim347's Avatar
Refrigerator beeps
2015 RP171 dometic three way fridge. With camper level, on any power source, periodically the fridge beeps. Will beep thirty or more beeps, quit, then do it again. This can go on all day. I plug in to shore line at home, the night before leaving, to get the fridge down to temp. Ideas?
Tim347 is offline   Reply With Quote
Old 04-25-2016, 12:04 PM   #2
Head Rambler
Is the gas turned on?
Battery charged up and disconnect switch on?
Is it cooling correctly?
Any errors on the front panel?
Gotta go campin!
Old 04-25-2016, 12:38 PM   #3
I pulled this info from the internet. This appears to be condensation in the door latch alarm. Some people use a can of compressed air (for computer keyboards) to dry the wires/circuit board.
"The problem lies with the wires and plug into the rear of the lamp unit becoming coated with condensation, which somehow activates the warning system - 30 beeps for 20 seconds repeating every 2min 40sec.
The cure is to pull off the plastic cover over the lamp unit, dry the wires and plug, and all is well - until the next time I assume.
A feature of the "fault" is that the fridge does keep working despite the alarm, so there's no need to switch it off if you can put up with the beeps until you are advised of the cure - OK if you can go out for a walk, but no good to sleep with."
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 04-25-2016, 01:48 PM   #4
Tim347's Avatar
Wilco... I think that's it!!! I recall seeing condensation inside the blue tinted cover at the door latch striker. I pulled the cover off and wiped the condensation off but wasn't able to blow it dry. I'll pick up a can of compressed air and give it a try this weekend. Thanks for your research.
Old 04-25-2016, 07:23 PM   #5
kymooses's Avatar
Yes that is the fridge door panel issue. Unplug the light, dry it, follow the wires to where they go under some tape and you can caulk that area to help.
Travis & Carrie
181g - MoosePod Adventures Map
RPod Owners Map
kymooses is offline   Reply With Quote
Old 04-26-2016, 12:02 PM   #6
Tim347's Avatar
Blew it dry with compressed air and caulked under the tape. Let you know after this weekend's trip. Thanks for your help.
Old 04-27-2016, 08:33 PM   #7
kymooses's Avatar
Also be sure the door is latching and sealing all the way around. Sometimes a door that isn't aligned well will let the moisture alarm have fits.
Travis & Carrie
RPod Owners Map
Old 04-30-2016, 09:34 PM   #8
Tim347's Avatar
Not a beep all weekend! Caulking did it. Thanks for the help. 👍
Old 05-01-2016, 11:23 AM   #9
kymooses's Avatar
Travis & Carrie
RPod Owners Map
refrigerator
