Originally Posted by jackmaus
Took new RPOD 179 on maiden voyage over the weekend. Campsite water flowed freely through bathroom, but only dribbled at kitchen sink. Also, kitchen sink drain apparently not tight. Leaked into drawers below. How would I check the water lines to make sure that there's no leak or blockage?
If it's dribbling at the sink it's likely construction debris right at the end there at the aerator for the faucet. Especially if hot and cold dribble equally the same.
Unscrew it and clean out the faucet and you should be good to go.
