Old 09-16-2017, 11:06 AM   #1
RPOD 179 Plumbing issue
This is the first time I've posted here. Hope I do it right! I had to pull the bathroom faucet assembly out to deal with a leak. In the process the small washer came off the hot water elbow and fell into the cavity below. (Sigh - I'm getting pretty clumsy as I age!) You can see what it looked like on the cold water side.
Question is, do I need it? The cone washer fits pretty tight on the stem. If the washer is required, do I just need to order a new elbow assembly from the manufacturer? Looking for some advice from you RV repair wizards.
Name:	RPOD Plumbing 1.jpg
ID:	151556   Click image for larger version
Name:	RPOD Plumbing 2.jpg
robintanner is offline   Reply With Quote
Old 09-17-2017, 10:34 AM   #2
SeaDog's Avatar
Welcome to the forum its a great place to get your questions answered. looks like the fitting is pulled apart get a new pex fitting (from the hardware store) and install it.
Retired Navy
2016 Flagstaff 26 FKWS
Old 09-18-2017, 07:29 PM   #3
When I checked at our HW store they didn't have anything that looked like this. The missing flat washer is what apparently holds the screw cap on the fixture. I still have the screw cap and cone washer but not the flat washer.
Old 09-18-2017, 07:40 PM   #4
https://www.amazon.com/dp/B007AHMDA6...a-350120530481
Jmkjr72 is offline   Reply With Quote
plumbing
