Old 07-07-2013, 07:52 PM   #1
rPod 3way Refrig.
Hello
What kind of temperatures are you seeing in the refrig. & freezer compartments?
I have mine turned all the way down ( all blue light segments lite) and it just does not seem as cold as it should be.
I would like to get some group input,
Thank You, Mike
mfMcFroggierPod is offline   Reply With Quote
Old 07-09-2013, 05:12 AM   #2
We've never measured the temperature in the refrigerator. You were not very specific about what "cold enough" is.
We've run it on all three power modes and it seems to work fine. Butter stays hard. Some people actually keep ice cream in their freezers. We keep two frozen water bottles in ours and they stay frozen. Of course they probably contribute to the rest of the foods staying cold enough. (which is why we keep them there)
2010 r-pod 171
2011 Silverado 1500
Nights camped 2013: 94
Peggy L. is offline   Reply With Quote
Old 07-09-2013, 06:32 AM   #3
TURBS's Avatar
Have you put a temp gauge in fridge to see what temps your getting?
How long are you allowing the fridge to cool before adding food and beve items?
One thing I have found is cooling fridge down 6 hrs then adding items the day before we leave so fridge has ample time to recover again and equalize.
Albeit I've never had a three way fridge I'm wondering if there's mods to aid in better cooling as we do with our two way fridges.
Turbs
Old 07-09-2013, 08:39 PM   #4
I start the fridge up 24 hrs before I plan to load.
Refrig. 40*F
Freezer +10*F
My ice cream is mushy....
OAT 75*F
Dometic Refrig/Freezer 4.? Cuft
My Norcold worked fine 8 cuft
Old 07-10-2013, 10:10 AM   #5
fonzie's Avatar
Did you start fridge on DC only or AC or Gas....DC should be used once fridge has reached proper temperature?? What model number is your fridge?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 07-10-2013, 12:19 PM   #6
My father has an R-Pod and we noticed it is best to start the fridge on 120volts.
electrician549 is offline   Reply With Quote
Old 07-24-2013, 12:07 AM   #7
I found the reference
Note volts and Hz different from US
