Old 04-13-2016, 07:13 PM   #1
Sanitizing 2015 179 RPod.
I mixed 1/2 cup of bleach with a gallon of water, Filled the fresh water tank about half full, and poured the bleach solution in the tank and topped the tank off with fresh water. After about 4 hours, I ran the chlorinated water from the storage FW tank through the lines. It smelled like celery. I asked my wife to smell the water. When she entered the trailer she said she smelled bleach. But, when I turned on the water she agreed that it smelled like celery. What should I do?
Bearlover is offline   Reply With Quote
Old 04-13-2016, 07:16 PM   #2
I'd drain the FW tank, refill with clean water, drain, refill again, pump that through the lines and see if it still smells like celery.
If it does, break out the mayonnaise.
2011 Traverse LT, 3.6L, FWD
Old 04-13-2016, 07:32 PM   #3
Don't you mean peanut butter?
Old 04-14-2016, 11:28 AM   #4
kymooses's Avatar
I'd maybe let the solution sit in it longer. I leave mine sanitizing overnight before I flush. But at least celery isn't too bad of a smell.
Travis & Carrie
181g - MoosePod Adventures Map
RPod Owners Map
kymooses is offline   Reply With Quote
Old 04-14-2016, 06:49 PM   #5
I emptied and refilled the water tank. The smell is not as bad, and it is only from the kitchen sink faucet not the shower. So, that is an improvement. Thanks for the replies.
Old 04-15-2016, 12:15 PM   #6
Bearlover, do you belong to the RPod Owners facebook page and the RPod Owners Forum? There is so much info there specific to our rigs. You might find the exact answer you're looking for.
Debbie and Erv
2013 Lily Pad
Jeep Liberty or Town and Country Mini van
DebbieHM is offline   Reply With Quote
Old 04-15-2016, 02:17 PM   #7
Rpod Forum?
I thought this was the R-Pod forum. Can you give me a link. Thanks.
Old 04-27-2016, 01:05 PM   #8
Problem Solved
Since the original faucet was not working well, had a very low flow, I replaced the faucet with a really nice one made of stainless steel and brass. The water flow is great, and the smell is gone. I took the sink out to get to the connections and found that the edges in the cut out for the sink were bare. The trailer is less than two years old, and I saw a short section of the counter top starting to swell. I sealed the raw edges before I reinstalled the sink. Thanks for the help.
