Old 11-23-2012, 08:28 PM   #11
Originally Posted by dretired View Post
Or save a ton of $$$ and buy a 4,000 watt Champion with the 30 amp rv plug
Save a ton of $$$ at the expense of noise and fuel consumption. I've parked next to noisy generators it sucks no nice way to put it.
2013 Wildcat 323QB
08 Silverado Crew Cab 2500HD Duramax-Allison
Twin Honda 2000 campsite friendly generators
Nights camped in 2014 = 19
(2013 = 36)
(2012 = 42)
JFM-jr is offline   Reply With Quote
Old 11-23-2012, 09:09 PM   #12
Travelin Man
we have 2 honda 2000 gens and really like them, we can run out air with both and can run the micro with just one. we used to have the honda 3000 but it is heavy and hard to load and unload so sold it and bought the 2 2000's. the 3000 runs quieter and can run as long as 12 hours at just idle speed. it also had electric start, which is a plus, but we still like the 2000. if you can lift or have room for the 3000 I would go with that over just one 2000. if you are looking at getting a larger RV in the future then you would have the gen you would need already. cost is about 2000 bucks for it or less now but well worth it. stay away from the less expensive gens as they are loud and use a lot of fuel compared to Hondas or yamahas. no one likes someone that runs a loud gen in a campground. Colemans are another one that are loud.
if you can afford the option you can get a remote start on the 3000 unit. makes for a nice option when the weather is bad. either way you cant go wrong with a Honda or Yamaha, they run quiet and efficient.
good luck!! enjoy the rig!
Douglasdh62 is offline   Reply With Quote
Old 11-23-2012, 09:32 PM   #13
We have had a TT since 2005, now being replaced with a class C Solera. Here is my experience with a single Honda 2000 in those 7 years.
1. At home, elevation 200 feet, the generator will start the a/c, but if the a/c cycles off/on then the generator circuit breaker will trip.
2. As an experiment I turned off all circuit breakers in the trailer except for the a/c. The generator was able to run the a/c, including numerous stop/start sequences for over an hour before I gave up. My guess is that it was the convertor supplying charge power to the batteries that pushed the load over the limit. I think I can run my a/c at least for lower elevations by turning the converter off.
I can carry my Honda 2000 on my side with one hand easily. I could probably carry a second Honda in the other hand. I can not carry the Yamaha 2400 because it requires that you use two hands and carry it in front of you. My back, frequently, will not allow that to happen. There is a big difference for me between carrying that much weight in front versus alongside.
Because of my back, I would opt for a pair of Honda 2000's over the single Yamaha, if I wanted a reliable way to run the a/c. I use the a/c once every 2 years. We camp mostly in the Sierras. All I have to do to cool off is camp at a higher elevation. I never camp below 5,000 feet in the summer.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
Old 11-23-2012, 11:03 PM   #14
fast murray's Avatar
I bought a Honda 2000 a couple of years ago. I'd like to get the companion at some point. They are WAY easier to handle than the 3000. I would never consider a loud generator for camping. I don't even like them on a jobsite!
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 11-24-2012, 01:37 AM   #15
Originally Posted by Douglasdh62 View Post
The 3000 runs quieter
That's true only at an idle if you put the load of an AC on a 3000 it will have to work at a higher percentage of output than 2 2000s will. You would then be comparing for example the noise of a 3000 running at 75% vs the 2000s running at 55% I know with my twins feeding my AC they are raised just above idle and give a nice synchronized hum barely audible from inside the camper.
2013 Wildcat 323QB
(2013 = 36)
(2012 = 42)
Old 11-24-2012, 06:23 AM   #16
sail2liv's Avatar
Champion 4000
I made my choice based on cost and when would use....the noise is about like a lawnmower.....and we only use briefly when cooking or charging batts......but it is heavier than a honda....but not heavier than two hondas......it will run multiple items ..... including the big a/c....but I am
not comfortable running the a/c with it as do not want to mess the unit up....but anything else runs fine......carry it in back of truck and that is where it runs.....can t beat the $299.....for no more than we use....always plug the surge protector into it so can check the voltage and amps......I have always run sensative equipment thru an inverter powered by batteries.....only time you really need one is if you are boondocking more than a few days.........best of luck with your shopping..
2011 Silverado 2500HD 6.0 Gas 3.73
2013 Flagstaff 8524 RLWS
1978 Cape Dory Ketch
sail2liv is offline   Reply With Quote
Old 11-24-2012, 12:06 PM   #17
I always find the math interesting. I paid around $900 for my Honda 2000 in March 2005. So far that means I have spent $9.68 per month. That is not enough to break my bank.
I spend $4.00 per day on coffee at the office. That is $7,440.00 for coffee since March 2005.
The Honda, in comparison to my coffee habit, was a bargain.
Old 11-24-2012, 02:16 PM   #18
hotrodj125's Avatar
We are with 'deretired', we have the champion 4000 and it does a great job for us at a fraction of the cost.
Rod & Linda Johnson
Cedar, Minnesota
2006 F-250 SD 4x4 6.0
2012 Columbus 320RS
K-9's Lucy & Lizzie
Enjoying Life 1 Campground at a time
hotrodj125 is offline   Reply With Quote
Old 11-24-2012, 04:39 PM   #19
yvesm's Avatar
I went thru 3 Champion generators in a month, then I decided to get my money back and get a Yamaha inverter. The Champion generator was also real loud.
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 11-24-2012, 09:01 PM   #20
bikendan's Avatar
though i'm an admirer of Champion and their generators, i've heard the 3500/4000 model. IMHO, it's a great gennie for boondocking but not appropriate for a campground.
i strongly suggest you actually listen to the Champion and compare it to an inverter generator, such as a Honda or Yamaha.
the Champion 2000w inverter gennies are less expensive alternative to the Hondas and can be paralled. and they are about as quiet.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
