Old 05-07-2018, 02:21 PM   #1
Tank drains
Here is the new fresh water tank drain and the low point drainsClick image for larger version
ID:	171005Click image for larger version
ShickshinnyJoe is offline   Reply With Quote
Old 05-07-2018, 02:23 PM   #2
That should make it easier!
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 05-07-2018, 02:24 PM   #3
Yes do not get wet either
Old 05-07-2018, 02:26 PM   #4
Prime Member
The extra hose should slope downward. There is an upward arch in the new hose section which means some water will remain.
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 05-07-2018, 02:32 PM   #5
Just looks funny it is all down slope pex tube heated up bent down tank drain is off bottom never drain completely
drain, tank
