Old 06-25-2017, 04:07 AM   #1
Water dripping from 2 small pipes sticking down below shower
2 small pipes about 1 inch each tight together that appear to be capped sticking down below the camper and dripping steadily on the axle.
What are these pipes? I assume they should not be dripping...
flyinghigh is offline   Reply With Quote
Old 06-25-2017, 05:28 AM   #2
Sounds like your low point drains, is one red and one blue by chance. Usually don't have caps but do have valves that can be opened and closed, if you can post a picture it would help.
Retired Navy
Indiana
Hemisphere Lite 327RE
Silverado 2500HD 4x4 6.0 gas
Sailor Bill is offline   Reply With Quote
Old 06-25-2017, 05:39 AM   #3
fonzie's Avatar
If like these, then low point drains. just tightening the caps might stop leak.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-25-2017, 05:40 AM   #4
Yes, low point drains. Mine have caps with rubber stoppers in them that tighten to seal. Be careful not to lose the stoppers.
HallWNC is offline   Reply With Quote
Old 06-25-2017, 06:06 AM   #5
thanks so much gentlemen. I have the rubber stoppers. I will try to get them tightened up enough to seal.
Old 06-25-2017, 11:37 AM   #6
With a great deal of effort I was finally able to get 2 wrenches on each one and carefully tighten enough to stop the dripping. It appears the previous owners had not noticed or cared...the metal on the axle below has a lot of rust vs the other side.
I guess I am not clear though...what is the purpose of these 2 "low point" drains?
Old 06-25-2017, 11:52 AM   #7
DAISY BOYKIN's Avatar
Low point drains
These drains are for draining your hot and cold water pipes for winter storage.
Sid, Lois & HRH MISSY Terrible 3s SHIH TZU
2011 ROCKWOOD 8285 WS
2014 F-250 KING RANCH PS 6.7L/SWD/6R140/BFT
DAYS CAMPED 2018 60 DAYS
DAISY BOYKIN is offline   Reply With Quote
Old 06-25-2017, 11:54 AM   #8
fonzie's Avatar
When it's time to winterized your unit for winter, you open both cap to empty water from the lines so these don't freeze....
https://www.youtube.com/results?sear...nterize+and+rv
Fonzie
Old 06-25-2017, 01:12 PM   #9
john5646's Avatar
I installed two valves and garden hose fitting to terminate with caps. for ease of use. And it allows you to connect a garden hose on site to use as an exterior faucet. To wash grill, toys ect. Can choose hot or cold also. Click image for larger version
john5646 is offline   Reply With Quote
Old 06-25-2017, 03:50 PM   #10
Ahh....I get it now. Thanks everyone!
show, shower, water
