Old 06-12-2015, 05:15 PM   #1
Water Temperature
How hot should the water get using the electric heating element? Mine has been on for 24 hours, and it would give a nice shower, but not be hot enough to wash dishes. Also, is the heating element all or nothing, or can it be working at a diminished capacity? (kinda like some people I know)
Bearlover is offline   Reply With Quote
Old 06-12-2015, 05:43 PM   #2
KDHfan's Avatar
One temperature only. Unfortunately, they can't be adjusted. Electric or propane should not matter as far as the temperature. The only advantage to having it set to propane is a faster recovery time. However, an advantage of setting it to electric is your paying for it in your site fee, might as well use it.
2015 Coachmen Apex 288BHS
2014 Toyota Tundra 5.7L CrewMax
2014 Toyota Tundra CrewMax 5.7L
KDHfan is offline   Reply With Quote
Old 06-12-2015, 05:52 PM   #3
Check the bypass valve on your water heater. I suspect it's not fully closed. Another guy just had the same problem earlier this week.
See this thread:
Is your shower water hot?
Post #38 on page 4 of the thread shows an excellent pic of what your valves should look like.
2011 Traverse LT, 3.6L, FWD
Old 06-12-2015, 05:57 PM   #4
Charles Firth's Avatar
The hot water tanks are small, only 5-7 gallons (I think). Mine recovers fairly fast. We do take Navy showers to conserve the hot water. I usually only use mine on electric. I never tried it using both propane and electric, I think my suburban will not run on both. The propane shuts off when the water reaches a certain temp. Using propane will heat the water faster. I use the campground power that I paid for.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
Charles Firth is offline   Reply With Quote
Old 06-12-2015, 05:58 PM   #5
You probably have 132 hi limits on both propane and electric. You can replace them with 142 hi limits if you want. We did and found out it takes less hot water to accomplish the tasks.
Old 06-12-2015, 06:12 PM   #6
OC and Charles - The OPs problem seems to be the opposite of the other thread I linked to. He has hot water for shower, but not for dishes. Other poster had hot water in kitchen, but not in the shower. Probably same cause, but relative locations of the shower, kitchen and HWH are making the problem swap locations (shower vs kitchen).
Old 06-12-2015, 06:22 PM   #7
Rockfordroo, I agree I did not read it properly, the by pass must be in the wrong position. Although I wonder what would happen if you were washing dishes and someone else taking a shower how would the water be distributed. I guess it would be about the same as your home. I had my by pass in the wrong position on our first camping trip, plenty of hot water in the tank, but nothing coming out the faucets. When I finally took a long hard look at it I realized it was operator error.
Old 06-12-2015, 06:28 PM   #8
Charles - yeah, I had my bypass valve break (wasn't open, when the handle said it was). I only got hot water for about 5 secs, basically the small amount of water near the HWH that got hot by conduction from the water heater. In about 5 sec it would get swamped by the cold water from the bypass valve. Really took me a while to figure it out, since the valve APPEARED to be in the correct position.
Old 06-12-2015, 06:39 PM   #9
Could be, but the temperature to take a shower and to do dishes is quite a difference. TOWTA wants scalding hot water for dishes but only tepid for a shower.
Old 06-12-2015, 06:43 PM   #10
mark0224's Avatar
Has to be bypass. Sounds like hot water tap only is turned on in shower and the bypass is acting as a mixer valve so shower temp is comfortable and in kitchen that temp isn't good enough. If the valve handle forms a t with the pipe the valve is off if it is any other position it will mix cold water with the hot.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
water
