Old 03-13-2016, 12:38 AM   #1
4 Rear Interior Outlets Not Working
I currently have a 2012 29ft Sandstorm fifth wheel. I was vacuuming (Gen. power)on Monday went back on Tuesday to vacuum (Gen. power) and the 4 rear outlets are currently not working now. The vacuum did not die on Monday. I reset/tested the GFI near the bathroom (Only GFI in the fifth wheel) even tho it did not trip, switched all the breakers, plugged into house power, I tested the 4 plugs and they all have very low power being supplied to them. Everything in the trailer works besides those 4 plugs.
My next step is to replace the GFI. If that does not work I have no clue what it could be. Any tips or suggestion will be greatly appreciated.
Nate White
Sandboynate is offline   Reply With Quote
Old 03-13-2016, 01:59 AM   #2
caper's Avatar
Check for a loose wire on one of the outlets. Most likely the first outlet in the chain. The wire could have slipped out or burn off.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 03-13-2016, 07:30 PM   #3
I just replaced the GFI in the bathroom. The 4 rear interior plugs still do not work. Next step check for slipped or burnt wires within the chain.
electrical
